Will the extended seat from a 2017 rt limited fit on a 2014 RT Limited
Printable View
:agree: ….. on those models the attachment points ( for rear bolts, the post to secure the seat to the frame, and the indentations to match the " Y " frame ) …. are the same ( including 18 & 19 models also ) ….. the 2020 has a different seat ….. Mike :ohyea:
I'm trying to replace the seat on my 2014 RT Limited with an upgraded one. How do I find out which seats are interchangeable?
Bob, From what I understand is all seats from 2010-2019 are interchangeable. This is from the BRP.com website:
Quote:
Comfort Seat for All Spyder RT models
Compatibility: All Spyder RT models 2019 and prior
Hope this helps. Hope I didn't violate any rules.
r/Bob
If you go make the change, an easy DIY job, be certain to watch a Youtube video about changing it and be certain to block off the hole below the rear of the seat so you don't lose any parts into the black hole.
The only difference is between the early (2010-2013?) and late (2014?-2019) Comfort seats. All Comfort seats fit all 2019 and prior RTs but the early ones didn't have a cut out for a backrest. Easy enough to fix, though.
Sent you a PM Bobcarlson60 :thumbup:
