just got a new leftover 2018 rt limited. is there a way to set the clock on 20.8 update to 12 hour time verses 24hr?
Printable View
As mentioned above. It is as easy as going through the settings. When you get to 12/24 hour....just click on the 12 section.
You guys can see the clock???? I added a dash rack and have ananalog clock on it. Easy to see.
I have a 15 RTL. My clock runs fast. I'll gain some number of minutes over a week or so. Do you have this? Is there a setting in BUDS or other way to get it more accurate?
Rob
Yeah, I can see the clock. The numbers are small, but I can still see them most of the time. If the sun is glaring on the screen I can't see much on it, but soon as the road curves it is visible again.
I am retired anyway...... the only reason I need to see a clock is to know when it is time to eat.
I got tired of resetting the clock on my '15 RTL, so I bought a $20 Casio "diver's watch" at Walmart. It sits nicely on the right side of the handle bar and keeps great time.
Thanks Gwolf holding changed it but no 12 hour was present. Dealer tried setting it before I left but could not get anything but 24 hour format.
When you make changes to the clock settings you have to verify the changes by hitting the check mark moving the 'mouse' button to the right. The check mark will blink and settings will be saved. Hope this helps. The check mark will show up as you move the highlight to the minutes. The check mark doesn't show in the picture but it is in the white dot on the right.
=bob=
