Any one have this problem?
Replacing wires on fender now there is no power?
Is there a fuse?
Printable View
Is there a fuse?
There are no individual fuses to each fender....but if you are replacing the wires I would start by checking all the connections and seeing if you have power at the source of your new connection. Did you check power with a meter or just the light connection..? if you are using LED bulb remember they are sensitive to the correct +/- connections...:dontknow:
I had power till i hooked up the LED....... can I reset it or how do i fix it?
Is any of the LED wires rubbing on anything under the fender?
What year is your spyder?
Deanna
i took them off now there is no power to the light with none of them connected
2012 rt
Brand new and yes they all work it the top side and back fender units
Figured it out you will never guess what it is?
Maybe forgot to plug the harness back in under the A arm???
Yeah but in the strangest spot the female connector on the wire harness 35 bucks later FML!
