FOR A 2017 SPYDER RT SE6, COLD WEATHER STARTING BELOW 40 DEGREES F
I am looking for any suggestions on getting my chariot started when the temps go below 35-40 degrees up here in CT. I have heated gear & try to ride year round, conditions permitting. I use a battery tender junior at all times when parked in my garage (not heated). Sometimes in the upper 30's, low 40's, I can work at getting it started. But it sure is stubborn. I have used a light bulb under the engine in my garage, and that works. But if it is parked for a long period time (no engine heat remaining), and I am not at home, I don't relish getting stuck with it not starting.
I have only had this bike for a year, and am looking for ideas/suggestions from all of you that have had a lot more time with the 1338 cc engine.
Thanks.
PS: I just had the oil changed to the can am oil winter grade- 0W40 full synthetic.
