If you are considering - BLEEDING the brakes
With the assistance of my son I just finished this chore ..... I followed the advice given by some of the folks here .It went pretty smoothly and I didn't get any Bubbles to deal with ..... I started by re-moving the front wheels ( so much easier this way )... I cleaned the reservoirs - removed the caps , noting which way the arrows were pointing, on the rear reservoir I was able to extract most of the fluid with a Kitchen BASTER .... The front one wasn't possible because of the float inside ..... the rear Resv. is for the front brakes the front is for the rear ( thanks BRP for that logic :roflblack: ) ..... Left front first, then did the open valve .. pump and hold ...close valve ... about 8 times ...then added some fluid to prevent bubbles ...repeated this until the fluid became much clearer ( that means you've completed an exchange for that line with NEW fluid ..... then did the same on the right front brake etc.... then did the rear ..... I had been procrastinating about this job because I'm so used to doing everything by myself - alone :banghead: .... But my son was willing ..... I had 41,000 miles on this fluid and the rear resv. wasn't much dis-colored, the front was more so but not BLACK like some have reported .... there is now a better pedal feel than before but not hugh ....... Until I tried a full-blown PANIC type stop ....:yikes::yikes::yikes: .... I almost hit the windshield with my puss :roflblack: ...... I'll have to remember that, emergency stopping will be majorly effected .......... good luck if you try it ..... PS I only used about 10oz for the job ......Mike :thumbup:.....PPS I won't need a BUDS reset..PPPS, I did not do what " PMK " does with His brakes ..( see post #7 )( His bleed & flush is the BEST way it can be done :thumbup: ).....Because of what I've read here the 5% ( or less) that didn't get flushed because I didn't do the ABS is my decision based on time and effort to accomplish that ..... I'm not worried about the very slight difference ..... jmho .....Mike :thumbup:
