Filling gas to the rim or?
Hi folks!
When filling up your gas, do you stop at the pump shut-off or do you fill it to the rim? (Well, not quite the rim because closing the gas cap will cause overfill, but you know what I mean).
When filling up the gas comes up to the rim and then bubbles/settles down into the tank. It does this several times before I can't fit anymore into it. Is this a bad idea? Should I just stop when it clicks off the first time?
Thanks!
SS
WELLLLLLL NOW THAT YOU MENTION IT
Quote:
Originally Posted by
Mazo EMS2
Why not just do what you do with your car or truck?
You can't do it this way because The Spyder has no NECK ....you can see the top of the tank ...... on your car / trk there is generally more than 8 inches of pipe before it gets to the Tank .... on the Spyder you can actually see the gas tank ..... Mike :thumbup:
Easy Rider
Yet.
Doesn't it concern you at all that:
BRP says not to do that.
Other owners have reported that they DO have problems caused by over-filling ??
I guess not. I hope your luck holds up.
You are partly correct , some owners - the ones that have / had the V-twin engine and the way BRP routed the gas overflow and the position / location of the EVAP / Charcoal canister .... This ALL changed with the 1330 engine & frame .... Now only fumes can reach the canister ....not gas ...... Mike :thumbup:
