F3 Clutch updated to vacuum assist.....
Well, I did it this weekend... installed the F3 upgrade clutch 'kit' to get the vacuum assist.
I have the installation instructions from BRP in a PDF format... going to doctor them up a little and then will share with anyone who wants them.
It's a simple install, but also a pain in the ass. Getting the hose that runs from the clutch cover to the intake snorkel off the intake was a royal pain.... and I ended up breaking the 'nipple' off. :gaah:
I've got some pics I'll share when I get some time. Instead of trying to epoxy the 'nipple' back on I decided to plug the hole and then just drill a new one into the snorkel. I then used a 1/4" threaded to barbed PVC fitting and epoxied it to the snorkel. At least I think it was 1/4"...it was small for sure. This gave it better stability since the threaded part went inside of the snorkel. The hose went on the barbed side just fine.
The hoses are barely long enough to reach to the other side where they have you put the solenoid, which I ended up zip tying instead of mounting with screws.. it's just too damn tight to do much work in there!
One thing the instructions leave out is which way to have the arrow on the check valve point. It should point TOWARDS the air intake (away from the solenoid).
Anyhow.. it works like a charm and my carpal tunnel will be happier now!
While I had it apart I also put in Lamont's LED headlight bulbs and his LED foglight kit. Both were super simple installs and well made products.
If anyone wants a copy of the PDF install for the clutch, send me a PM with your email and I'll forward it over. I'll also try and see how to post a PDF out here.
