FRAME HITCH ... VS. SWING ARM HITCH
Quote:
Originally Posted by
Doc Humphreys
As someone that has a little experience in fabricating, not sure if you have figured on the swing arm travel. It is pretty substantial in relationship to the frame (about 5-7 inches). That is one of the reasons most manufacturers use the swing arm to attach to. Not sure if there are enough hardened points under the tupperware to hold that the way you want it to.
The tongue on the trailer is going to move up and down with the suspension. Not sure how well that will tow, but cagers do that all the time. You may be on to something there. Will be interesting to see how it turns out/how well it works.
Best of luck!!
:agree: ..... I loooooove DIY'ers ..... and not to throw water on this :banghead::banghead::banghead: ..... But you do realize that any EXCESSIVE movement of the trailer tongue ( up & down ) means the rear wheel must be LEAVING THE GROUND :yikes: in order for this to occur. Because the rear wheel is attached to the swing arm !!!!! ..... and when you think about it the rear of the Spyder is what goes up and down on the rear suspension. The Spyder is not a Moto-cross bike ...... if you are riding around with the rear tire bouncing on the pavement .... imho something is wrong .....Mike :thumbup:
