Go with LEDs for longer life and brighter light than halogen
Quote:
Originally Posted by
djhobin
To Mike, on the 2013 ST, it does not have the shutter system. The high beam did burn out. I still had the low beam available. The right side headlight still had the High beam available. I drove the Spyder with both low beams on until I had them replaced.
Dennis
Yeah, but doesn't he have the 2014 RT-S, which I believe does have the shutter mechanism. So, if there's a problem with the shutter, replacing the bulb isn't going to help.
Either way, I would agree that LED bulbs are the way to go. Brighter light and much longer life because there's no filament to break. No, I don't believe it's a warranty item - normal maintenance on any vehicle.
As for Xenon, HID and the like - way more expensive and not necessarily any better than LED.
If you replace the headlights with LED, you will probably also want to replace the fog lights for appearance sake if nothing else. THOSE are a bear to get at on the RT, so unless you've got the skill, patience and determination to do them yourself you might consider having everything done at the dealer - or at the next Spyder rally where the vendors like TricLED are there to sell and install them.
Good luck.
Here is a nice article about what is best...Its all about the housing design...
- 02-07-2017, 02:27 AM
Corsacreek
http://www.spyderlovers.com/forums/i...er-offline.png
Member Join Date Nov 2016 Location South Florida Posts 24 Post Thanks / Like http://www.spyderlovers.com/forums/i...llapse_40b.png
http://www.spyderlovers.com/forums/i...cons/icon1.png
http://www.spyderlovers.com/forums/i...quote_icon.png Originally Posted by Dray http://www.spyderlovers.com/forums/i...post-right.png
So feel free to jump in hear with thoughts, opinions and experience.
Thanks in advance.
Dray :yes::yes::yes::yes:
When you say "The Best" do you really mean it or are you really asking what is among a sea of cheap imitation the best of the crap out there????
Because if you want the best then you would buy the genuine product made by Philips which is the 12953BWX2 series type that run from $250 to $300 and they are made in Japan. They are bar coded and can be verified in Philips website as the real deal. Anybody here claiming they have the best are taking you for a ride. You'll find plenty of cheap imitations on ebay running from $18 to $45 with the Philips logo and they are all 100% FAKE and violation of copy right infringement. Philips has already sued several Chinese factories over this.
Most people are naive and don't take the time to properly research what's being sold as snake oil. There are differences in quality among cheap imitations but the bottom line is that they are ALL made in China with very little quality assurance. What you pay someone $100 for a pair of LED headlight bulbs will have the same quality assurance as the $40 one you bought on ebay straight from China.
Now if you really were interested in maximizing the potential of your headlight power you would start with the obvious, who made the headlight enclosure/assembly and that would be Hella. The assembly was made for a halogen bulb which projects light 360 degrees so right off the bat you have reduce your lighting power by using an LED bulb. An HID bulb would be a better candidate because it projects light at 360 degrees and with a higher color temperature. The HID covers ALL of the headlight reflectors and projects the light correctly. My old 95 Prius which I sold several years back is still has the original HID bulbs with the original ballast and still kicking. I can't say the same for any LED kit I have bought.
Look at the new Ducatis and BMW bikes that have LED
headlights and you'll see the difference in the assembly. You certainly wouldn't put a halogen bulb no matter the price on the bike with LED reflectors would you???
http://www.spyderlovers.com/forums/i.../paperclip.png Attached Thumbnailshttp://www.spyderlovers.com/forums/a...1&d=1486452296
- Post Thanks / Like - 1 Thanks, 3 Likes
http://www.spyderlovers.com/forums/d...ges/thanks.png SpyderCruiser thanked for this post
http://www.spyderlovers.com/forums/d...ages/likes.png PMK, larryd, SpyderCruiser liked this post
Thank for this post
