2012 RT LTD clicks but won't start
Hi everybody,
I've read every post I can find on this subject, pulled every relay, pulled and checked every fuse, tightened every battery terminal, unit shows 12.8 at the battery and the frunk accessory 12 V plug as well as the brunk accessory 12 V plug, The dealer installed a new battery on 5/28/14. My dealer isn't open till Tuesday, anyone got any more suggestions? I suspect bad cell in the battery with less than 300 miles traveled however, no bulging on it. I have a 12V battery load tester and will try that tomorrow.
Appreciate any help - thanks,
Joe
Probably not very helpfull
There was a guy in the last two weeks that had the same symptom (sounds like anyway) and it turned out to be his starter had locked up. Not something I would try to fix at home.
bummer dude!
Thanks, but tried that repeatedly
Quote:
Originally Posted by
happyspyder2039
Foot or hand on brake then try to start
Thanks for the effort of reading and replying to my problem.
Load test verifies battery in perfect condition and fully charges
I guess it's on to my dealer now - have no trailer - we'll see how well BEST PLUS works!, to be continued
Had my foot on the brake every cranking attempt
Bob Denman
The only way that your bike could turn over while in first gear...
... if your foot was on the brake.
Give it another try... :thumbup:
"Says in 1st gear but I can't get it out. Always cranked in first gear in the past."
Had my foot on the brake every cranking attempot for 2 days
