Use a fused relay or can the accessory wire handle this current?
Evening,
I've recently bought an F3-T and was recently fitting a battery optimiser connection as I only use the bike occasionally. When I removed the frunk basket I noticed several accessories have been wired directly to the battery; 12v socket, Garmin GPS and dual USB socket in frunk. The USB has a blue light that is always on which may explain why my battery is draining.
I'm going to rewire these accessories through the 'customer accessory' wire underneath the frunk but wondered if it would be worth using a 4 pin fused relay for these accessories or does can the accessory wire handle this current?
Thanks.
