For those of you with a Garmin GPS with lifetime maps. A new map 2020.20 has been released.
PS this is a North American map.
Printable View
Thanks, Billy, I just got the word from Garmin but not the version number.
Thanks Billy. I just downloaded the newest version about an hour ago.
Guess I'll have to set it up to download overnight. My DSL SUX! At 1.2 Mb/s it'l take about 3-4 hours. Thanks for the tip!
Thanks Man
Speaking of Garmin, my ZUMO 660 battery is dying (won't hold a charge) and I can't find a replacement locally. I'm being told by some "good luck, it's a Garmin only item and it's probably not supported anymore." Curious...….Has anyone had to replace their battery for this item?
Just loaded up my 3 Garmin's with the 2020.20
Zumo 595 Done
Nuvi 3597 Done
Nuvi 3790 Done
Thanks Billy
thank you for always keeping us updated !!
There is a slider on the bottom of the Zumo 660. Slide it and the battery cover door will release. Take off the door and there is the battery. Also there is the usb plug you use to connect to your computer to update the firmware and maps.
PS Here is a link to the owners manual. https://www.gpscity.com/pdfs/manuals...-EN-MANUAL.pdf
https://www.amazon.com/Replacement-0...6CWMV3M1QP0FZR
Battery for Garmin Nuvi 500, Nuvi 510, Nuvi 550, Zumo 220, Zumo 600, Zumo 650, Zumo 660, Zumo 660LM, Zumo 665, Zumo 665LM, Aera 500, Aera 510, Aera 550, Aera 560 GPS Units
Anyone else running out of memory space? On my last updates(haven't done this one).....on two 665's & one 660, I had to limit the geographical area updated, because of lack of memory space.
Here's a fix for the 590 batteries which may work for 660 ones if they have a similar connector:
http://outsider-adventure.blogspot.c...ttery-fix.html
Fixed my 590 battery this way.
I have a garmin lNUVI40 with lifetime maps. I just purchased a 2013 RT with a ZUMO 660. I updated the firm ware, but the map update costs $49. Does anyone know if there is a way to update the ZUMO with the NUVI update?
Appreciate it very much.
There is a fix for that. It is not the battery, it is the contacts . Here is a link that explains how to fix it. http://www.totally4bikers.com/blog/b...a-few-minutes/
Appreciate the thought anyway :thumbup:
Thanks for the heads up.
I used to dread these map updates. I had Frontier Communication as my internet provider.
It could take as much as 4 hours to update the maps.
I have two GPS. One for my Van and another for my Spyder.
That's 8 hours to update maps. I'd start running the update before I went to sleep and let it run all night
I changed to Xfinity about two weeks ago.
I'm doing the update now. About 30 minutes for each GPS.
WOW, what a difference.
