Supporting the Spyder on ramps
To install the Baja Ron anti sway bar, I've got to get at least 22" of clearance under the front of my Spyder. My car ramps don't come close.
I've got a couple of 2 by 8 boards I can set up as ramps, but I don't know what they can hold. Since I'll be under the bike I'm a bit concerned.
Assuming the boards are in good shape with no cracks, can 2 by 8 ramps be trusted? The Spyder weighs just over 1000 lbs, and since these will be supporting the front I'm guessing maybe 700 lbs will be supported by the ramps, so 350 lbs each. Boards are 8 feet long and I'd angle them at 30 degrees or so.
