Brake Failure and again again!
I've had a brake failure message several times..I've reset it myself several times after numerous attempts! I've also taken it in to the dealer twice in 2 yrs... 1st time they did a flush, new pads, reset, ect at a cost of almost $1000! 2nd time they just reset - cost... $275! This time, I've been trying for over a month and it wont reset... I'm at my wits end! Is there another trick or something to do before I trade it in (2012 RT Limited only 10000 miles, 2000 since the brake job) on a Vanderhall! Thanx for any help :popcorn:
Moisture in the brake system
wilpir -- you don't mention date and mileage when problem occurred but I assume recently which implies you didn't change your brake fluid for about a decade, most of which was sitting in storage. So I think BajaRon has identified the most likely problem -- stuck caliper due to moisture in the system. The maintenance schedule for brake fluid is replace every two years.
Replace brake fluid four times
So you replaced the brake fluid four times before your dealer did it 2000 miles ago?
The math ain't adding up for me. I'm sticking with BajaRon -- it's a caliper.
