I have no idea what I did with my tire plug kit so I'm going to buy a new one (which means I'll find my old one as soon as the new one shows up). What does everyone recommend? (Links, please.)
Thanks.
Printable View
Thanks.
I've always used the cheapo sticky strings with fresh glue each season and I carry one of the Xlime pump compressors.
I, on the other hand, have had several. This is the kit that I carry, along with a small Harbor Fright :yikes: compressor.
https://www.nealeytirerepairkit.com/repair-kits
https://www.harborfreight.com/12v-15...tor-63152.html
One advantage of the Nealey kit is that the strings are used DRY, so there is no tube of cement that will dry out.
None are 100%, that being said I've used the cheapo sticky string plugs on trailer tires with a high degree of sucess. I also carry the slime kit with their small flat compressor and a small bottle of slime. The sticky string kit will also fit in the slime kit bag and it lays flat in the bottom of my frunk taking up as little space as possible.
Don't forget if you get a screw in your tire you won't get it out using your finger nails. Get a Leatherman.
Have helped others with flats and have experienced them myself. My Royal Star Venture seemed to be a magnet for flats. I Cary the Stop and Go kit and have been very pleased with it. Probably have used it 6-8 times over the years.
https://www.stopngo.com/
Bob
Dynaplug Ultralite tire repair and their Micro compressor. It all fits in the compressor bag and takes up very little room.
I worked in a tire shop many years ago, we used a plug kit made by SAFETY SEAL. Best kit available. $48.00 dollars, worth every penny
Weather you find old kit or not good idea join AMA to get the roadside assistance deal with the automatic renewal
https://americanmotorcyclist.com/
Sure like what it coves & ease of use. Has worked great fo me so far anyway (dont rely on exclusively)
PLUS all the other benefits with being a member
i have the stopngo had to repair tire on my truck worked very well ,dont think the plug could come out being mushroom shaped
