Aluma 638 Trailer - Issue & Repair
Just a heads up.....We carry our 2018 Spyder Ltd on an Aluma 638 behind our motorhome. This year we headed out from Maine To Az. Stopping for a vehicle check we found that the tongue was at a 20 degree angle in relation to the trailer bed. Upon investigation we found 2 of the 3 tabs holding the tongue to the bed had broken away.....the welds had broken. Luckily there was a Lowe’s nearby. We drilled a 1/2” holes through the bed and tab and installed 1/2” bolts. The fix worked and are now in Az. We will get everything rewelded and install additional supports. The Spyder is not too heavy for the trailer but think the weight distribution is too far forward maybe causing excessive tongue weight.
