I understand I have minimal adjustment on my stock 2022 ryker 900 sport front shocks , but is there a spring I can utilize to get better handling over bumpy roads ? Answers or suggestions are very much appreciated.
Springs carry the weight. Shocks handle the damping.
If you want more control and damping then you'll need to upgrade the shocks. Elsa has a few options.
Have a look at martinthevlogger's site at his H&R springs.
I would change the swaybar first - maybe you take than the front shocks of the new 2022 Rally .. they are longer
Yes I did put a Baja Ron sway bar on . I am receiving my H&M’s springs from martinthevlogger Tomorrow. I actually found some perfect fit springs from Summit Racing also, so if the H&M’s springs don’t do it I’m going to buy a set from Summit Racing. I will not buy shocks from Elca, way overpriced,
Hope you keep us updated on how you like them. I have a set waiting to be put on my Rally whenever it arrives (together with the H&R swaybar).Quote:
Summit racing has 0800.0200.300, 350,400,450,and so on lb/in spring rate . Look up Eibach coil over springs . Perfect fit!
H&r front springs from Martinthevlogger. For the can am ryker 900 sport. I am very impressed as the new springs make handling in corners much more level, therefore you are not fighting the negative force when turning . I found they handle the bumps with a much more controlled bounce ( rebound ) . The “dip “ felt with original springs is gone. The combination of MartinTheVlogger H&R springs and the Baja Ron sway bar has transformed my ryker into a much more secure tracking and controlled handling machine.
Yes Markubis I have rally shocks on my sport, I did mean 0800.0250.300 etc. Sorry, they don’t make 2” id coil over springs .
Great info Tucker01
I'm in Canada and there is a company that imports the H&R springs
would you have the specs on them?
THKs
