Fuel Consumption Averages
I just finished a 5826 mile trip from Ohio to California (Corbin seat) then to Chicago (Spyder event) and back to Ohio. I pulled a trailer for the entire distance. I kept good records of my fuel consumption using "GasHog" app on my iPhone. I documented EVERY fill-up for the entire trip. The stats are summarized below.
Distance 5826 mi
Total Fuel 212 gal
Average MPG 27.81 mpg
27.43 mpg using 91 Octane
28.64 mpg using 85/87 Octane
Average Fuel Cost
91 Octane $3.04/gal
85/87 Octane $2.81/gal
NOTES: Fuel consumption was essentially the same no matter what Octane was used. Actually 85/87 Octane was a little better though probably not significant. Cost difference at $0.23/gal IS significant. Standard Deviation was 3.55 mpg.
According to BRP (at the Tech tent) the ECU adjusts for lower Octane but he says that the fuel consumption should be about 15% higher. Such is NOT the case.
Max Distance is therefore about 171 miles on 6 gal.
Average MPG before the trip, without the trailer, was 28.72 mpg. so there was a slight increase (28.72mpg > 27.43mpg) in fuel consumption with the trailer.
Hope some of you find this info useful.:lecturef_smilie:
