I finally did it! Bajaron's sway bar!
I just installed Bajaron's sway bar and there's definitely a difference, much flatter and more stable. But what a task to install it. Getting it up the required height wasn't so bad. Plus after I got it up there with a jack I put enough cement blocks under the tires to make sure it stayed up. And I had jack stands as additional back up further back on the frame. So it was secure and I had ample room to work underneath it. Sorry no pictures. :dontknow: The toughest part of the job for me was the replacement of the new nylon spacer in the channel.
With the ST being a "sporty" version, you'd think that kind of stability would have been standard. I strongly recommend it but hopefully you'll have someone that's done it before right next to you the whole way. I wish I had. But like I said its worth it! :2thumbs::2thumbs:
