Transmission Filter and "O" ring
Good Morning:
Does anyone have a source for the NEW style transmission filter for a 2012 RT SE5? My dealership is smoking crack. They want almost $25.00 for the filter and "O" ring.
:yikes:
I spoke with Baja Ron. He does not carry them and BRP was no help either.
Thanks for you help.
Ed
Teddy did some dig'n & found what you need
Quote:
Originally Posted by
Jerbear
Just an FYI:
Teddy pulled up the BRP Parts Order page for a 2012 RT SE5 like the OP has, and it says that the 'transmission' Filter is 'NOT AVAILABLE' :yikes: 420956745 ***OLD DISCONTINUED MODEL***
So just out of curiosity, Teddy pulled the same up for the 2013 RT Limited (SE5) & it came up as 'AVAILABLE' :clap: 420956747 $13.12 & the Oring is $1.99 420650500 & those are the parts numbers.
So you can order them yourself & have them shipped to your dealer for free for a total of : $15.11 :clap:
Why not every other oil change?
Would be nice if BRP would allow going two oil changes on the Xmsn filter like they once did. Back then, the shorter filter apparently had some issues, like collapsing, and that may be why they went to replacement at every oil change. Later they came out with the extended cap and filter wire covered outside and inside to prevent collapsing. Seems to me this one should be good for 2 oil changes. But then there's the old "warranty bug-a-boo".............:banghead:
Top quality car filters are good for 15K and more. My Accord calls for filter change every other time and some of these car filters are really tiny!
