gromets on 2010 Rt s panels
the gromets dry out and when you push the panel back into them they will push on through leaving a hole and the panel with nothing to grab onto. Mine had the little wings on the covers that went behind the frame member but were very hard to get in place. I used the Lammot method and cut the tab wings off so the panels would push in a lot easier. i found that a little 3 in 1 oil on the gromets would allow the pins to push in very well. also i added some tie wraps to the panel and through a hole on the spyder so if a panel came off it would only dangle and not "go home". When i get back from my trip (in South Dakota at the present time on the spyder) I will glue the gromets in place.
