2011 RSS SE5 headlight issues
After a ride today, I found that the headlights were on, even with the ignition key out.
With the key out, they can be changed from low to high beam.
The relay has been changed, and fuses checked.
The 2 lower outside pins (85 & 87) on the relay are both live, the same as all the other relays
I did not find any voltage inside the LH headlight switch to indicate a live wire, but this needs to be checked.
Can anyone offer any idea what may be the problem here.
The Spyder is stock standard, there is no modifications to the wiring.
