Garmin 665 on 2014 RT-Limited
My Garmin 665 will not work on XM with the factory installed cradle and harness for the 660. All other functions work fine. I have the XM40 antennae plugged into the harness. Harness for the 660 and 665 are the same part number.
Any ideas as to why or what I will have to do. Not interested in anything going thru the speakers from the 665 as I use Sena bluetooth in my helmet. Nav and MP3 now is going thru speakers and bluetooth. XM, Traffic, and weather are not available. 665 has been checked and is working in all functions.
Jack
Garmin Zumo 660 Problem--Update
I am having problems getting the NEW Garmin 660 mount to transfer to my F3.
I took the mount apart and find that power gets to the printed circuit board inside
the Garmin Mount but it does not get to the power pins for the 660 GPS. From this
observation I deduce that the GARMIN MOTORCYCLE MOUNT FOR THE 660 IS
MISWIRED on the PC board inside the mount.
I don't know why this is so but I do not see any way to fix it. Garmin must have a
bad batch of motorcycle mounts and, maybe, they are dumping off a known problem
to Amazon.
I will call Garmin and try to get to the root of the problem.
Quote:
Originally Posted by
Bootie
I purchased the Garmin No. 010-11270-03 Mount from Amazon and IT DOES NOT WORK WITH MY Garmin 660.
I think I have found the root of my problem. The Mount that I ordered from Amazon and UPC label on the Garmin Motorcycle Mount Box says Motorcycle Mount Kit 010-11270-03 but the mount inside the box says 011-02023-25. The box [made in Taiwan] contains the wrong product.
I will try to get the correct mount when I am at Pit Bull for Spyderfest 2016 and try to get my money back from Amazon although it is not their problem, it is Garmin's.
