3 Attachment(s)
my saddle bags and top bag
givi side bags from givi , fit great and cheaper than BRP .i have a givi top rack that was designed to fit with the BRP side mounts .i had to do some bending and painting but in the end it fit nicely .i wanted to get the small givi top mount but by the time i went shopping it had been discontinued .so i had to adapt .the top bag is a monokey kappa 49 .i can haul a lot of stuff!
3 Attachment(s)
top bag mounting frame and the bends
3 Attachment(s)
You might want to redo that rear strut attachment
There have been cases of owners cracking that rear strut. The stock mounting uses two separate nut/washer combos and that design stresses the thin tubes at the holes.
I finished my conversion this weekend. The struts are attached using a simple U-bolt I got from the hardware store. The bonus is that the u-bolt has a plate, and spreads the load over more surface area; decreasing the likelihood of the strut failing.
I went this route because it doesn't require hacking up the original Can Am tail piece and I don't have to shell out $$$ for the sport rack and hack that up too. Instead of bending the top arm, I cut off the plate and will have it re welded once I get the mock up complete.
