Handlebar Riser Kit for F3
Is anyone aware of either a handlebar riser kit or reasonably priced replacement handlebars for a F3-T. I just bought a Corbin Dual Tour seat which I love. The down side, however, it increased my reach to the handlebars. I need to move my existing bars up and back 1.5" to 2.0" to sit straight up and reduce pressure on my wrists. Any help will be appreciated.
Thanks,
ShadyGrady:banghead:
The important question for me is, Will the length of the Control cables on my 2017 F3
Limited allow me to use the Rox 2" risers without having to reworking everything??
Anyone with experience please feel free to jump in here. I have a 3000 mile trip coming
up and would really like to install the risers before I leave.
Dray:yes::yes::yes::yes:
I do recommend the Rox risers. I got mine this morning and installed
them on my 2017 F3L. They were the 2" risers and I could have probably
gone with the 3" ones. They have a lot of adjustment range. You will need
a small star Allen to remove the cable clips on each side of the handle bar
down close to steering stem. Also needed will be a 7MM Allen to remove/
reinstall the 4 bolts that were holding the handle bar. If extra cable length
is needed, remove the top right access panel (one where you check oil) and
using a flashlight, look up under the top cover and there should be tie wrap
around 2 or 3 small wire bundles. Clip this and you are ready to put everything
back together. Follow the included instructions when tighten everything back down.
Ride safe and enjoy!!
Looking to buy risers also
Quote:
Originally Posted by
PrairieSpyder
I sat on a Spyder with the short reach bars and they are not enough for me.
What size Rox's did you go with? I am thinking bout 3" or 4".
Do these install fairly easily?
How about Handlebar Risers for an ST-S?
Sorry about the thread hijack...but I didn't find much under the ST forums...
Follow-up to original post
ShadyGrady
Thanks,
The 2" Rox Adjustable Risers were an easy install without changing the factory cables. I have a Corbin Dual Tour Seat and the Rox definetly put my hands in a more comfortable position. I removed them however due to a couple of issues I could not fix. (1) any position that moved my hands back from the stock position partially or totally blocked my view of the rear view mirrors (2) the 2" risers
seemed to give my bars too much flex and the steering did not seem to be as responsive. I removed them and although I have to lean slightly forward I am much happier with the stock set up. Not quite as comfortable but a better overall riding experience.
Thanks,
ShadyGrady :riding:
