Looking for a directional rear tire. Has anyone tried this tire on the Spyder? 215/60 R15
Printable View
:popcorn::popcorn:
I have one on the rear of my 2014 RTS for close to 35000 miles...It is due to be replaced this winter when I service the bike for next riding season...Many on here have used this tire and everyone loved it...The only problem is Michelin has not manufactured this tire in about 5 years...So be careful, its probably a VERY OLD STOCK ITEM...larryd
I have had Michelin tires on mine for years...but not that one
The Vredestein Quatrac is essentially the same pattern and is highly rated.
https://www.tirerack.com/tires/vredestein-quatrac
Have you considered the Riken tire Mike recommends. Apparently Riken is a well established tire company from Japan and part of Michelin.
He raves about the tire, even over the Vredestiens
OK thanks for the replies. I am now between the Vredestein Quatrac 205/60 and the Riken 215/60. The Quatrac specs claim 24.8 diameter and the Riken at 25.2. Which one brings the speedo closest to the GPS for MPH? That will be my deciding factor between the two.
THIS IS GOING TO BE MY NEXT REAR TIRE...LARRYD
$86.40
Hankook H737 KINERGY PT All-Season Tire - 215/60R15 94H quantity
ADD TO CART
DESCRIPTION
REVIEWS (0)
New from Hankook and made in their new Tennessee factory! This is a Premium Touring All-Season tire that replaces the H724. This tire features Improvement in performance compared to the H724 with increased mileage as well as improved wet and dry performance. This tire comes with a unprecented 90,000 mile tread warranty!
Tire Only – Wheel Not Included
Treadwear Warranty: 90,000 miles
Road Hazard Warranty
Speed Rating: H
Long Mileage
Comfortable Ride
Excellent Performance in Wet and Snowy Conditions
Specifications
Features: Treadlife: N/A
Tire Size: 215/60R15
Vehicle Type: Car
Tire Width: 215
Tire Speed Rating: H
Tire Season: All-Season
Tread Depth: 9 mm
Brand: Hankook
Assembled Product Weight: 21.37 lb
Model: 1023465
Manufacturer Part Number: 1023465
Manufacturer: Hankook
Assembled Product Dimensions (L x W x H): 25.03 x 25.03 x 9.30 Inches
At pectolcoope store, we strive to combine with manufacture to provide the price as low as possible with the Brand New best quality of produ
The Quatrac 205/65 puts the speedo dead on with the GPS. No more variance.
Calibrated our speedometer to match the GPS by making calibration changes via BUDS. With the equipment and understanding how its done, any tire size can be dialed in for 0.0 error.
Opens up the possibilities to run whatever tire a person decides upon that is best performing, regardless of speedometer errors.
Vredestein Quattro, NO such tire at TIRE RACK, The same guy has called it wrong twice in this thread.
T.P.
Getting a name like that a smidge wrong & calling it a 'Quattro' instead of a 'Quatrac' is easily done T.P. :opps: How many times have you seen other members calling the OEM tires 'Kendra' or 'Crapenda' instead of 'Kendas'?? :dontknow: Yeah, orright, maybe that latter Kenda mis-naming really does apply & could well have been deliberate, but still.... :p
Anyhow, if you look at the link RayBJ provided in his first post, post #6, you can easily read the proper tire name off the end of the link: OR you could click on the link & see ALL of the tire's details direct from the supplier! :ohyea:
Check it out, here's a copy of that link: https://www.tirerack.com/tires/vredestein-quatrac
When researching Spyder tires, knowing the Spyder is a fraction of a car / SUV weight, I only consider High Performance tires and will not consider Touring tires. Grip on a lighter vehicle is important.
If these ratings and test results were compared in a manner, that rated performance comparing all tires on the same scale, when tested for dry traction, snow, quietness and more, the results would be more useful.
Simply, the highest rated Touring tires, will be a fraction of the grip offered by High Performance tires.
Consider, a fully loaded Spyder, at max published weight, including passengers and cargo, is about 1700 pounds for an RT series. The F3 series will be lighter, as will no cargo and a single rider of 210 pounds fully geared up.
The best scenario would have the weight distributed 50% on the single rear tire and 50% on the pair of front tires. This would place 850 pounds on the rear tire. Comparing, a Honda Civic, would have a similar weight on a single tire as the fully loaded Spyder rear tire.
Under the same calculation, the pair of front tires sharing 850 pounds would each see only 425 pounds per tire.
Knowing Spyders have a forward mounted engine, front suspension, two front wheels, can load more weight in the frunk, and typically the heavier rider is positioned forward, the weight bias seems to move away from 50/50. I personally have never measured corner weights of a Spyder. I do realize as the numbers shift towards a more weighted front, the rear tire weight decreases, and with that the tires ability to grip the road surface decreases.
Many folks do run touring tires, and report acceptable performance for themselves. Hopefully the limits of grip are never needed. If Touring Tires offered the best grip, it seems high performance sports cars would be delivered with them. I highly doubt owners of high performance cars are replacing performance tires with touring tires as an upgrade.
Merely consider all factors and priorities when deciding. Myself I take grip over tire longevity for the Spyder.
Also, with it now fashionable to be concerned about tire date codes, and many folks insisting that tires older than 7 years old need replacement, one should consider miles per year ridden on the Spyder. We often see these touring tires going 30,000, 40,000 and maybe more miles before replacement. That requires about 5,000 miles per year on the Spyder at a minimum.
I do not recommend specifically what tires folks on this website should run. But do, as you read, recommend performance tires over touring tires.
Currently on our Spyder. A pair of Federal Formoza fronts and a Yokohama s.Drive rear. The Yokohama was marketed as a high performance summer tire and not for cooler road temps. Like many tires, over time they are discontinued and newer models are released. The s.Drive is no longer offered.
Mike, simply prove me wrong...do you seriously believe a touring tire has equal or better grip than a high performance tire? If not equal in grip, or more grip, then yes, it is a fraction of the grip.
It would be so much nicer if these tire tests compared all tires on the same scale for all parameters. Problem though is the lower ratings, if done this way, for lesser performing tires, would hinder sales.
My issue is with the wording you used ...... a " fraction " of the grip, to me means less than 1% ..... So the Touring tires have less than 1% of the grip of High performance tires ????? ....which equates to - High performance tires have 99% MORE grip than touring tires. ..... this isn't possible ....... Mike :thumbup:
