1 Attachment(s)
Check Engine/Check Transmission
Hello All,
Was riding to work this morning and half way through the ride when I switched to 5th gear I got an E on the screen and then it keep saying check engine / check transmission. I pulled over, turned off the bike and turned it on and all went clear so I started riding. I went again into 5th gear and same thing, at this time I realized it was when I was getting to 5th gear it was getting the error. The bike was running and all just getting that error. I kept riding and then it started happening in 4th gear. I almost got to work and then it wouldn't get out of first gear until i pushed the up shift hard (SE5) and then if i let off the accelerator it went into E/N.
I don't like the symptoms it's presenting and I hope it's not a big big burden on my head.
When I did the oil change /exhaust replacement, I got the check transmission light once but it went again. Read on the forums it happens if you do an oil change.
Please help :bowdown::bowdown::bowdown::banghead::banghead::ba nghead::banghead::banghead::banghead::banghead::ba nghead::banghead::banghead:
