SpyderLovers.com
Go Back   SpyderLovers.com > SpyderWeb > Spyder General Discussion
Notices
Spyder General Discussion Can Am Spyder Forum. Talk about all things Can Am Spyder related.
Reply
Thread Tools Display Modes
Old 11-03-2009, 11:59 PM   #31
kromc5
Quote:
Originally Posted by Tom in NM View Post
kromc5, I am 5'7" and have the Madstad and like you I had a real hard time with windshields, mainly because my helmet is soooooo bad, noise-wise among other things.
But like the others have said, the MadStad works. It must be magic or something. I have tried a bunch of settings on it and have found 5 that work very well for me. Today, since it is cooling off, I went to full up and put the top forward about 2" - there is no turbulence on my helmet and I have at more than a hand length (7") before I feel any at 50 mph. I get air flow, but no blasts and no pushes from behind.
If you can, try out some of the adjustable shields. You can buy just the RoboBrackets and mount other shields on it - and I know that Rlathen was able to just buy the CHAD brackets and used another shield. I really think you should be able to test a windshield out. CalSci seems to have a good return policy. The MadStad RoboBracket is also satisfaction guaranteed.
I liked the CalSci, but this performs so much better for me - especially with my helmet.
I put some pictures of the shield and hardware in my Albums, take a look. I hope you find what you are looking for - to me, the windshield, seat and handlebars are the most important mods you can do for comfort and safety.
Tom
Thank you very the excellent feedback on the windshields. So I can keep the Calcsi and add the robo brackets to increase the height? I just found the robo brackets site but did not see the listing for the spyder and how much I can increase the height of them.
Thank you
kromc5 is offline   Reply With Quote
Old 11-04-2009, 12:06 AM   #32
mrb
Senior Member
mrb's Avatar
Quote:
Thank you
About 6" or more if you wanted - at a guess.
http://www.madstad.com/s.nl/sc.7/category.493/.f
__________________
Martin - Oz Spyder #930 http://www.spyderryders.net.au
mrb is offline   Reply With Quote
Old 11-04-2009, 12:59 AM   #33
kromc5
Thank you for the feedback and the link, the manaul refers to cutting the windshield which is little unnerving. I would hate to have to cut the Calcsi to install this. Though it does appear that this would not be needed. Just finished speaking with a customer in Brisbane from Suncorp.
Old 11-04-2009, 01:53 AM   #34
mrb
Senior Member
mrb's Avatar
No need to cut the windscreen - that is for other motorcycles. Mark makes a plate to fit where the Spyder screen mounts and the brackets fit to that.
"This DIY (Do-It-Yourself) kit is for those that want to convert their current fixed Spyder windshield into an adjustable one. It includes an adapter plate that replaces your stock shield, adjustable RoboBrackets and all the hardware you'll need for attaching your windshield."
Mark now includes a template so you can drill holes in the Calsci - after that it is a 10 minute job to fit.
__________________
Old 11-04-2009, 02:12 AM   #35
kromc5
Thank you for the continued help, I will give this a try before sending back the Calcsi.
Thank you
Old 11-04-2009, 08:20 AM   #36
bjt
Very Helpful Member
bjt's Avatar
Quote:
Originally Posted by Dragonrider View Post
That's what I thought until I took the chance & tried the Madstad 22"... I'm 6'4" and couldn't be happier...
Basically same results for me. I'm also 6'4".
Thank you
FYI, what you will have to do is drill new mounting holes in the CalSci windshield to use it with the Madstad bracket. I'm sure that will void returning the CalSci windshield.
I've tried 7 different windshields and made another 5 or 6 modifications (cutting down a very tall F1 Evo II and trimming an Evo III for a desired airflow) to two of the windshields I've had and the Madstad bracket and windshield has been the best overall combination so far.
__________________
Happy Spyder Owner
Thanks to Carlo for helping us through a tough repair situation.
bjt is offline   Reply With Quote
Old 07-12-2010, 07:32 AM   #37
SC_DOC
Does anyone know if the louvered vent made for GoldWing windshields will fit the curvature of the RT windshield? It sure would be nice to allow air through on a hot day (most days in SC). Or do they really make that much difference? Perhaps I should ask a GoldWing rider.
SC_DOC is offline   Reply With Quote
Old 07-12-2010, 08:31 AM   #38
bjt
Very Helpful Member
bjt's Avatar
Quote:
I don't know about the Goldwing vent but I had a F1 windshield with two circular vents in it and there was no appreciable airflow coming through the vents. I also had a CalSci which has a very large hole in the center of it and there wasn't that much air flowing through that. I expected a lot more air to be flowing through the openings in both those windshields than what I actually got.
__________________
Happy Spyder Owner
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBadvanced CMPS v3.2.1
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ICSW Member - International CAN-AM Spyder webring
Home/Join | List
Next | Previous | Random
Webring powered by alt-webring.com
Copyright © 2008 SpyderLovers
