Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Aug 2007
    Springfield, MO
    Default New temp gauge with bar readings
    I know we talk about our temp bars all the time and I wanted to get a more accurate reading on my water temps so when I do install the new spal fan controller I can tell if it's doing it job or not.
    As you can see from these pics the Spyder is no way running hot at 5 bars like some seem to think.
    @175 degrees I hit 4 bars
    @197 degrees I hit 5 bars
    @202 degrees the fan came on
    @190 degrees the fan kicked off
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    Where exactly is the temp sender located for the added-on digital temp gauge? Is it measuring the coolant temp as it exits the engine?
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
    Aug 2008
    Maryland
    I already shelled out the big bucks.
    Oh well, I'll just have a super cool
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Aug 2007
    Springfield, MO
    Quote Originally Posted by GaryTheBadger View Post
    Registered Users 3wheeldemon's Avatar
    Jul 2009
    Houston, Texas
    Quote Originally Posted by BeRight View Post
    +1 Same here
    3WD
    Today is a good day to ride!
    owner!
    [x]- Gun rack
    [x]- Helmet-mounted fire extingusher and DPS deactivation hammer
    [x]- Large print (senior version) safety card
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    [QUOTE=Lamonster;133446]I know we talk about our temp bars all the time and I wanted to get a more accurate reading on my water temps so when I do install the new spal fan controller I can tell if it's doing it job or not.
    As you can see from these pics the Spyder is no way running hot at 5 bars like some seem to think. I'm still going to install the controller but is it really needed?
    Lamont,
    As usual...great work!
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
    Jun 2009
    Vero Beach, Florida
    Awesome meter set-up!
    Happy Owner * 2013 RT Limited, 2009 RS SE-5
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Jim Alpha View Post
    Thanks. I got both gages with a sending unit for under a $100 bucks from Summit Racing
    Invalid Emails
    Jun 2008
    Yuba City CA.
    Thanks as always for your comments, this makes me feel much better as I was recently concerned about running at 5 bars and its nice to know what the actual temp is.
    I guess I should have gone ahead and put in a 'real' guage like yours (it's a great clean set up), as come to think of it all my other prior bikes came with the right stuff from the factory. Thanks again.
    Invalid Emails
    May 2009
    OH/TX
    Along this line has anyone installed a marine bilge blower?I see they are 12v. and big cfm for like $25.Glad to know the temps aren't menacingly high but I want the heat off the feet.
    Aug 2007
    Springfield, MO
    Quote Originally Posted by wolfshead1 View Post
    http://www.spyderlovers.com/forums/s...0&postcount=71
    Ran it for a while but I'm not sure how much good it did.
    Registered Users jedd's Avatar
    May 2008
    Tiffin, Iowa
    Thanks Bro I thought too much debate over water temp. I've checked mine with infrared gun and read what your pic shows. I think Spal may be a waste. Nice pics and info
    Happy Spyder Owner
    Aug 2007
    Springfield, MO
    Quote Originally Posted by jedd View Post
    I shot mine with the temp gun at the top of the radiator and at the bottom of the radiator and it's within 2 degrees of each other. Ideally I would have the sensor at the top where the water comes into the radiator from the motor but sitting still like it is there is very little if any cooling effect until the fan comes on. The temp readings would still be the same moving or not as the bars are in relation to water temps.
    Aug 2008
    MD
    Quote Originally Posted by Lamonster View Post
    The laser temp guns are really cool...I got one and hit the pipe before it connects with the hindle...curious how hot it got...it read in the mid 600s one time just after a long ride...I have copper silicone on there (temp. rating 800 degrees) so it looks like all is fine...haven't seen any of it drip off...
    Bone Crusher
    Registered Users gazey's Avatar
    May 2009
    Hobart, Tasmania.
    Anyone know how hot it has to get before hitting "limp mode"
    I have heard of a few Spyders going into limp mode sitting in traffic on hot days. What temp or how many bars are showing
    Andrew Gaze
    2008 Full Moon SM5 PE#979
    I am one very happy owner
    Aug 2007
    Greeneville, TN
    Lamont, how long did it take to go through the temp increases in your pics?
    Nice gauges, is that your 3rd or 4th set? I like these the best.
    Aug 2007
    Springfield, MO
    I don't know, was I suppose to time it?
    PhotoShop Master tatt2r's Avatar
    Jun 2008
    methuen ma/salem nh
    Stupid question but are they water proof
    THOSE WHO LIVE BY THE SWORD DIE BY THE SWORD... BUT...THOSE WHO MASTER THE SWORD SURVIVE BY THE SWORD....
    Rev. J. Proctor
    reverendproctor.com
    HAPPY SPYDER OWNER
    Apr 2008
    Jackson, MI
    Lamonster,
    Didn't your original analog temp guage show higher readings (10 - 15 degrees per bar) than the new digital one?
    Aug 2007
    Springfield, MO
    Quote Originally Posted by tatt2r View Post
    Not at all Bro. None of the gauges I've had on there are considered "waterproof" but they all did fine in the rain. These may or may not be alright but I could seal them up pretty easy if I needed to.
    Quote Originally Posted by BRPjunkie View Post
    Lamonster,
    This temp gauge will read 1 degree at a time.
    Apr 2008
    Jackson, MI
    I realize that, but I recall a photo of your original analog guage reading about 210 at five bars and the new one is showing 197.
    Active Member spyderwoman's Avatar
    Sep 2007
    morganton,nc
    Default can anyone tell me what this fault code is?
    my husband just checked my bike's temp. mine ran the same about 179 at 4 bars, 164 at 3 bars, anyway my husband installed a manual switch for me to turn on the fan at 4 bars instead of waiting until the 5 bars. (because mine went into limp mode too quick while in traffic saturday went from 4 to 8 bars in no time) but now my check engine light won't go off! it is showing a fault code of 0 P0480. does anyone have the fault codes and could you look this up for me? i saw someone post on here a week or two ago saying he could check the codes. do you think this has anything to do with the manual switch being installed or a new issue altogether?
    Registered Users rleathen's Avatar
    Sep 2008
    Ajax, Ontario, Canada
    As per the shop manual an error code of P0480 is as follows:
    Involved Module: ECM
    Description: Radiator fan relay shorted to battery +
    Cause: damaged fan, relay, damaged circuit wires, damaged connector or damaged ECM output pins
    Service Action: Disconnect radiator fan. measure voltage between harness connector 1-FB-C10 and ground (Expected value: 0 volts). Measure resistance between terminals 85 and 86 on relay (Expected value: 70 to 90 ohms)
    Since I believe I was one of the first few to install a manual override switch http://www.spyderlovers.com/forums/s...ad.php?t=12160 I would suggest that the wiring of your override switch has in all liklihood caused the problem. Just how did the manual override switch actually get wired in ??
    HAPPY 2008 SE5 OWNER 1" BRP Riser, NMN 3" risers, NMN Triple Play & Tail Light, Kewlmetal Mirror Extensions, Evoluzione Powerbus, BRP 23" Touring Windshield on CHAD Bracket, Ride-On in tires, J&M Integrator, Gerbings Dual Zone Temp Controller & Heated Gloves, 2 Dash Mounted 12V outlets, Kewlmetal Highway Brackets & Kuryakyn pegs, Trunk Spring Mod, Vista Cruise Throttle Lock, Kuyrakyn L.E.D. Battery Guage
    Sep 2007
    morganton,nc
    Default oops!
    he wired it straight to the fan plug at the bottom of the radiator fan. the relay and circuit was not even in the system and thats probably what triggered it...the relay was not plugged in. he had to put the relay back in to clear the check engine light. thanks for being so quick on explaining the code! you guys are so helpful i really do appreciate all of you techies!
    Sep 2008
    I assume that the removal of the fan relay and failure to reinstall it was just an oversight. I would not ever suggest leaving the relay unplugged not for the very fact that the computer will complain but also I would not want to ever rely solely on me to turn the fan on with the switch. I am too busy enjoying the ride to have to continually monitor the temperature, the relay is a fail safe to the override switch.
Tags for this Thread
