Results 1 to 25 of 50
    Jun 2015
    Sparks, NV
    Default New Viking Saddlebags
    Okay, so I decided when I bought my F3 that I was not going to pay the ridiculous price Can Am was asking for their saddlebags. They are very proud of their bags to say the least.
    I had a set of Viking bags on the Yamaha Raider I traded in on my F3 and I knew Viking had a universal mount for the unusual ride so I decided to give them a try. The Viking bags came in yesterday. First off, I'd like to say that in hard mounting the Viking bags you will have to do a bit of bag drilling. The bags are made from hard plastic and require the drilling of 3/8" holes for the brackets. When I held the bags up to the F3's mounting points, I found the existing pre-drilled holes in the Viking bags almost fit the F3 perfectly...."Almost". The rear hole was about a 1'4" off. I also found that the bags would not work with the passenger hand rails, which I thought was going to be the case. Lastly, I found that for a really nice tight looking fit, you would have to modify the Viking brackets, grinding them down a bit. All in all, it took me about 1.5 hours to mount the bags.
    1. Removed the seats.
    2. Removed the hand rails.
    3. Positioned the bags and marked the holes for drilling.
    4. I used the existing front hole and grommet for the front mounting point and removed the grommet from the last hole which had to be drilled slightly by about 1/4".
    5. Once I had the upper mounting holes set, I simply laid the brackets on the bag and marked the lower holes. Due to the bag size and the design of the F3, clearance was not an issue.
    6. For a clean look and to avoid the purchase of longer bolts, I removed about 1/4" of material from the upper end of the mounting bracket with a cut off grinder then smoothed it on my shop grinder.
    After fabrication, I simply bolted the brackets on the bag then bolted the bags to the F3.
    I think they turned out very nicely and I saved around $1,200 over the cost of a set of Can Am bags.
    Chris
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    look good with the f3!! how are they as far as water resistant, and do they have any rain covers?
    Houston
    They look great on the F3. Well done!
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2010
    Las Vegas, NV
    Default Bags
    Nice job! Looks great.
    Joe Meyer
    Nice looking bags. They fit in with the F3 styling well.
    Aug 2008
    Maryland
    Excellent - looks great
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Default VIKING BAGS
    ......BRAVO.!!!!! .....As you may know I'm an absolute DIY'er......so you have my deepest respect on this.......I have a question on one thing you said " ALMOST ".....1" 4" , OFF on where the hole needed to be ?.......was this a typo.....that doesn't seem to be almost............I can also picture re-placement " PASSENGER GRAB HANDLES "......You seem to be talented , so where the bags attach make a large " [ " shape with the flat on top and the ends extending down to the attachment BOLTS from 3/16 th flat stock (or if you can weld even better ) .....then slit a broom handle or large wood DOWEL and attach it to the sides of the flat metal.........WaLa passenger handles..............Mike
    Mar 2013
    Oz
    Default thanks
    Thanks for the pics & info. Jeff (husband) has a set of Viking Quartercircle bags sitting here waiting for his F3S (fingers crossed he may get it this weekend!) - lockable and waterproof, top quality too. Your pics gave us a good idea of how they will look on the F3, so thanks again. The lounge room floor also has smoothspyder backrest just waiting for his F3 (thanks, Jim).
    Apr 2011
    GREENVILLE, SC
    Default quarter
    i'm betting he meant a "quarter inch" Mike.... as in 1/4".... but datz just me...
    Dan P
    SPYD3R F3-S
    Apr 2011
    GREENVILLE, SC
    Default AWESOME
    Quote Originally Posted by ca8920 View Post
    Chris
    AWESOME Chris....
    can you give us a website for these bags...? model number, LARGE, mid size, or small.....? etc etc etc....
    Dan P
    SPYD3R F3-S
    Default TYPO
    Quote Originally Posted by SPYD3R View Post
    Dan P
    SPYD3R F3-S
    Yes I agree, but I don't like to assume .............What do you think of my Passenger Handle idea ?????..........Mike
    Apr 2011
    GREENVILLE, SC
    Default hmmmmmmmmmmm......
    i'll PASS on that 1 Mike.....
    a 'broom handle'......??????
    NOT....
    Sep 2012
    Junction City, KS, USA
    I love that Spyderlovers (others, but not me) have so much engenuity!
    PrairieSpyder (Patti)
    Aug 2008
    MA & NH
    That's a huge savings !
    Apr 2015
    Germany
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Looks great
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Active Member Kwalsh's Avatar
    Oct 2014
    cohoes ny
    you can find them with google, just look up viking bags they have a good site with lots of pics. i just put a set on my friends honda vtx and they are good bags and pretty solid , they look great on your f3!!!!!! so the question is what are you going to do with the $1200 you saved
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Bags look great!
    The Corbins are $1900+ I'll stick with the Can-Am bags and spend the $700 on more farkles.
    Very Active Member GunDoctor's Avatar
    Sep 2014
    Los Angeles
    What mounting brackets were used?
    Another Day To Be My Kid's Dad [emoji379]
    2015 F3-S. And Another Day To Be My Kids Dad
    Jun 2015
    Lagos, southwest Portugal
    Quote Originally Posted by Centhor View Post
    Looks brilliant. Some windshield, as well.
    Jun 2015
    Sparks, NV
    Default Grab Handles
    I was actually thinking of running down to my local Off Road Warehouse store and grabbing a pair of roll bar handles. They should fit nicely and look great.
    Jun 2015
    Sparks, NV
    Default Water Resistant
    Quote Originally Posted by spydaman60 View Post
    They are hard plastic so yes they are water resistant. They may have a cover, I don't know for sure, I'd have to check with Viking.
    Jun 2015
    Sparks, NV
    Default Mounting Brackets
    Quote Originally Posted by GunDoctor View Post
    The bags come with the mounting brackets. You can find the bags are under the Viking Universal bags area.
    Jun 2015
    Sparks, NV
    Default Viking Universal Bags
    AWESOME Chris....
    Dan P
    SPYD3R F3-S
    Here's the website address for the Viking Universal bags.
    http://www.vikingbags.com/motorcycle...saddlebags.htm
    Chris
    Jun 2015
    Sparks, NV
    Default Almost
    Sorry for the typo, yes I meant 1/4" off....
    Chris
Tags for this Thread
