Belt size
Does anybody know the size difference in a 2012 rt belt and a 2014 rt belt
Sent from my SM-G900V using Tapatalk
BELT SIZE
The only different size belt that I'm aware of is the 2015 F-3 ....all versions of it are different from all other Spyders........Mike
Yes the belts are different and I asked the question before. Did not get an answer.
Without being able to quote specifics : it's the same size, but has been built a bit stouter. (I think that this was done to handle the triple's increased torque output... )
Do you really know or is it just a WAG? So just to be clear you are saying that BRP sells 2 different belts and both will fit the same?
All that I'm saying, is that they're the same overall diameter...
They aren't interchangeable.
Definitely 2 different part numbers.
14 rt 705501304 Drive Belt
12 rt 705501576 Drive Belt
Why aren't they interchangeable? The RT with the 1330 engine uses the same pulleys as the 998 engine RT's.
They have two different part numbers for the front sprockets...
705502101 for 2012
705502106 for 2016
I didn't look up the rear sprocket numbers...
All that I can say is: proceed with caution!
705502101 for 2012
705502106 for 2016
Fronts both 28 tooth.
Rears have various part numbers depending on the color. But the same color will be the same part number.
