Results 1 to 12 of 12
    Active Member sawtooth's Avatar
    Dec 2012
    Horseshoe Bend, Idaho
    Question Safe jacking points on an 2012 RT-S
    I am a recent owner of a 2012 Can Am Spyder RT-S an only have 120 miles on the unit. I will be doing most all of the maintenance after the 1st 600 mile oil change at the dealer. I have two Goldwings and have done most all the maintenance on them so I feel confident I should be able to do most of the maintenance on the Spyder. At least the oil changes.
    Question: Is there jacking points for raising this unit as I like to get underneath to get the best look at what I'm doing? I prefer to get it up high enough to have it on jack stands at least.
    Also I have a tractor with forks (as in fork lift) attached to the hyd. bucket. Can I lift the Spyder with these forks? If so where is the best lifting points?
    Would it be best to approach from the side or the front?
    This forum has already answered a lot of my questions but I was surprised of the amount of folks that haven't read their owners manual. Some of the questions I read here could be answered if only the manual was read.
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    BRP recommends Jack points on the frame, two in front and one under the rear- most point of the frame forward of the rear shock mount. They recommend you NOT use the rear shock mounting point as it is not designed for that particular load.
    If I recall correctly, the Owner's Manual has further information.
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Springfield, MO
    GOS member (Girls On Spyders) CSW61's Avatar
    May 2012
    Perryville, Mo
    After looking at this link I was able to lift without an worries
    2018 RT Limited , Pearl White
    Dec 2012
    Morrton,Il.
    Default rt maintinence
    I hope you have a dealer as good as Lithgo in Hopston that we use. When we got our 600 mile service they let us go in and whatch the tec. he was very good and showed us how the panels came off and all the steps to a service. He also gave us tips for the lift we have a motorcycle lift and they had one too, Made a ramp and backed it on then put blocks under the frame in frount, lift away! Also saw one on utube that used car ramps for the frount and then jacked the back and put a ramp on the rear tire, kept it wide open. Have fun with it. The kit forpm from BRP is great has everything you need in one box.
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    Default Safe jacking points on an 2012 RT-S
    Active Member juliantrost's Avatar
    Jackson, NJ
    Quote Originally Posted by btcherm View Post
    Where could I get those stands? Thanks
    2012 RS SE - White. Sport rack with Backrest, ISCI Armrests, Two Brothers Exhaust
    Oct 2015
    Wales
    Quote Originally Posted by MarkLawson View Post
    I'm confused - where did you read that? My Service Manual (p50, section 4.3 of the EFI subsection) says:
    "Position a floor jack under the lower portion of the rear shock absorber and lift the rear of the vehicle until the rear wheel is off the ground."
    It goes on to show a photo of exactly that.
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by juliantrost View Post
    any wal mart or harbour freight. Tho his look home made and a very good job of it also.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Bet they're heavy and stable to!
    Oct 2022
    Washington
    From the 2013 BRP shop manual, it recommends using the rear shock as the lift point.
    2013 RTS , Yellow
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    I have a 2012 RTS also and I realy love my BigBlue for lifting the Spyder when working on it !
    They cost a bit, but so does the hours at the local dealers workshop. It have saved me a few trips. And it is good on my knees
    Youtube link to see how they work > https://youtu.be/DIoQuzc5sn0
    Brgds Martin
