DPS LIGHT
When I parked my 2010 RTa/cSE-5 6 weeks ago no lights or codes Iv'e been pushing it around the shop from place to place I started it this morning and got check DPS and a red eng light on the dash any Ideas I can't remember how to make it show the code with the mode button Thanks Neel
Originally Posted by Rattigan_Roger
If it is an RT
MODE - SET - TURNSIGNAL
I had the same issue with my RS.. And according to can am.. There is a recall on the 2010-2012 DPS unit.. May need to check that out just in case
neelbert,
Could this be a case of the battery being a bit low from the last six weeks of inactivity?
Can you throw it on a charger and see if that helps?
Good Luck!
Two codes PD551 and PD552 where do I find what they mead THANKS NEEL
I've got a battery tender on It
P0551 = Torque sensor open
P0552 = Torque sensor short to ground
The remedy for either is to replace the DPS...but I would charge the battery first and see if they go away. A low battery can cause all kinds of faults.
Well then, time will tell...
I paid for a extended warranty in Nov. It may be fixing to pay for itself
