Results 1 to 22 of 22
    Mar 2018
    Oregon
    Default Tri-Axis Handlebars - are they worth the investment?
    I'm relatively new to the Spyder world. Purchased my White RT-L a few weeks ago, and the first thing I did was install the Bajaron sway bar. Huge improvement in stability and steering.
    I heard about the tri-axis handlebars and was wondering what are their advantages because their price-tag is so high. Will they make steering easier on turns? will they be closer to me (I'm 5"4 with short hands)? Anything else?
    Thank you!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by CA-SPYDR View Post
    I'm relatively new to the Spyder world. Purchased my White RT-L a few weeks ago, and the first thing I did was install the Bajaron sway bar. Huge improvement in stability and steering. I heard about the tri-axis handlebars and was wondering what are their advantages because their price-tag is so high. Will they make steering easier on turns? will they be closer to me (I'm 5"4 with short hands)? Anything else? Thank you!
    It's a comfort thing. Doesn't affect performance. Think ergonomics.
    2014 RTL Platinum
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    Thank you!
    I agree with UtahPete, no change in handling performance. I had trouble being in the saddle for even 2 hours....the bars were just wrong. I got the tri-axis and afjusted them, and what a difference. Now after a few hours of riding, my butt gets sore, but shoulders and arms are fine. They’re damned expensive, but for me worth every red cent. Good luck.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    As a tall person, I could not make long rides without them!
    Along with other comfort items.
    If I bought a new Spyder today, I would have to have these things again.
    https://youtu.be/O9Xna_VjqOc
    Bob
    2011 RT-S SM5 - Black
    Active Member scarecrow's Avatar
    largo, florida
    Yes it is.
    2014 RTS , Cognac
    Jun 2010
    Las Vegas
    I would not have an RT without them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Tri - Axis
    I highly suggest you TRY them out .....$ 800.00 is a lot to spend and it you don't like them ...... Find someone ( forum member ) who has them and try them ......jmho ... Mike
    Add me to the list of Tri-Axis bar fans. I had them installed as part of the out the door deal because of my size and my Comfort Seat that moved me farther back than the OEM seat. You can tune them to make your ride most comfortable. Pricey, yes, but worth it IMO.
    Sep 2015
    Parkesburg,Pa
    Agree with all the above.I had them installed 1 month after getting my RT,no regrets,wouldn't be without them.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default They are the best
    For me the TriAxis makes riding a joy. It was killing me between my shoulders until I got them. Your being 5'4" it will likely help you bring the bars closer and up/down to your preference. You show as from "CA". Depending upon where you are, I'd think you could find a bike with them so you could see what it's like. I purchased mine before I had access to try anything hoping it would help. Thank goodness it did!
    Rob
    Thank you!
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Active Member 3 Wheel Rider's Avatar
    Jan 2015
    San Antonio, Texas
    I'll cast a vote for the tri-axis handlebars as well. I'm 5'2" and used to experience a lot of pain in my neck, shoulders, and back after about 2 hours of riding. My arms were so stretched out with the stock handlebars to the point that I could barely reach the outside handgrip when the bars were turned full-lock left/right in turns. Changing to the Tri-Axis bars resulted more control of the Spyder, more comfort for me and eliminated the pain. I wouldn't think twice about buying them again if I was shopping for a new Spyder.
    ... JMHO -- I would also stay with the black ones and stay away from the chrome bars. Reason: The bars have a lot of surface area and in my opinion the chrome bars would cause a lot of reflection enduced blindness.
    2014 Spyder RT Limited SE6
    BRP Tri Axis Adjustable Handlebars
    BRP Adjustable Wind Deflectors
    BRP RT Passenger Armrest
    BRP Driver's Backrest
    BRP Travel Cover
    Baja Ron Swaybar
    SpyderPops KOTTS
    SpyderPops Bump Skid
    Lamonster NVB Highway Brackets w/ Gripper Pegs
    Lamonster LED Headlights & Fog Lights
    Custom Dynamics HMT Brake Light
    Show Chrome 7.5 inch Spiral Antenna
    SpyderFlap Mud Guard
    Helmetlok w/ T-Bar Extension
    Hopnel 5PC Luggage Set
    Airhawk R Seat Cushion
    Rivco Dual Flag Mount
    Sep 2014
    USA
    Add me to the Tri Axis bar list of happy campers.
    Just wish I could adjust them a bit higher vertically. Similar to APE Hangers but not that high
    Mar 2015
    NE Kansas
    I installed a set of Tri-axis handlebars on my wife's RT two weekends ago. It was a long job but Finless Bob has an excellent 3-part video on how to do it. His videos gave me the confidence that i could do it myself and were constantly played and re-played as I moved through the install. Now, after having installed the new bars, i can tell that there is a dramatic difference in comfort level. Most notably, there is a significant range of adjustments which can be easily applied, tested, adjusted, etc. I think this is one farkle that is well worth the investment for comfort on long(er) rides.
    Aug 2012
    Central Coast, CA
    I have the triaxis bars on my RT. I didn't like the bar angle, so I negotiated the price and installation into the purchase. I too am a fan.
    If the stock bars aren't comfortable, then it's worth it. If they're marginal, then you might get used to them and after time grow to like it, but I would say that's somewhat unlikely.
    Depending on where you are in Commiefornia, you're welcome to PM me and try mine out and see what you think.
    2020 RTL SE6
    Active Member trikerbiker645's Avatar
    Apr 2016
    wi
    I like mine ok but if they would have made them so that the grip ends could also have rotated some they would have been perfect. By that I mean, when I get the bars where I want them for height and pulled back for the distance I like, the grips are just a tad too angled and put more angle on my wrists than I like. If you could adjust the grip angle after doing the height and distance to allow my hand and wrists to be a touch straighter, I would be 100% happy camper.
    Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
    Mar 2013
    [QUOTE
    ... JMHO -- I would also stay with the black ones and stay away from the chrome bars. Reason: The bars have a lot of surface area and in my opinion the chrome bars would cause a lot of reflection enduced blindness.[/QUOTE]
    I have a set of chrome ones on our RT for the last 3+ years, and have not had an issue with reflection or blindness.
    I not saying it's not possible - just telling you our expereance.
    I was looking for a set of black ones when I found the chrome ones for less $ than the black ones. Worked out well for us.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2016
    St. Charles IL
    It was either the Tri-Axis bars or surgery. I CHOSE THE BARS!
    Love 'em!
    Bill W
    2019 F3 LTD
    Phoenix
    Default Look around
    Thank you!
    I waited almost 2 yrs. My advice don't wait. I had shoulder pain strain I no longer have pain and strain. eBay Amazon or Leaders Inc had some of lowest prices at $650. I forget the can am part number. I got mine for $399.00 on eBay. The fla. guy bought but never opened them. Had ridenow install them. 3-3.5 hrs install.
    Jul 2017
    Quote Originally Posted by PW2013STL View Post
    [QUOTE
    I was looking for a set of black ones when I found the chrome ones for less $ than the black ones. Worked out well for us.[/QUOTE]
    I have the same situation with mine....I was able to purchase the chrome set at a discounted price two years ago and have never had any issue with sun reflection. To my thinking, it is of no concern, and esthetically speaking, I prefer the chrome.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Mar 2018
    Oregon
    Quote Originally Posted by marty1096 View Post
    good tip! Thank you.
    May 2017
    Mesa, Arid-Zone-A
    I don't have them. I have a friend who does. He and I are about the same size, 6' and "over" 250#s. His are adjusted to the most comfortable position for him. Today I sat on his bike and could tell virtually no difference between his bike and mine. I guess size matters.....
    Semper Fi
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    I put mine on after a year and love them. Wouldn't be without them. Also got the garmin gps mount since it came down in price. Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
