Front brake pad clips
Is even possible to get the clips without buying the pads?
Someone DIY made one for the back of pad not the one on pin. Think was out of music wire
SpyderLovers Ambassador
Pad Clips
You might check with 'BajaRon'. He is a vendor on this site.
ENJOY YOUR LIFE WITH A SPYDER
That would be me and it was for the left front on a 2012. One of the clips broke and at that time you could only get new ones with a set of factory pads. They are not available from BRP separately. According to their ads EBC now supplies those new clips with a new set of pads.
You need a really stiff wire to make this work. I went to my hobby shop and bought some piano wire in as close to the right thickness as I could. I did a very poor job of bending a replacement but after 2 or three tries I got one close enough that it has worked for about 10K. I thought I had a picture but I guess it is gone. ANy way if indeed EBC now includes the clips I would buy one set of pads just for the clips. I asked all the dealers in Utah but nobody had any spare clips so I had to make it and it worked so far.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Brake Clip #1.jpg So as I said before it took me a bout three tries to get it to this point. Fortunately the piano wire came in about an 18" length so I had plenty of material.
In the picture the clip on the left is the DIY replacement the clip in the center is the broken one and the one on the right is the good one. I used a real small set of needle nose pliers that I use in building model RR stuff. If this hadn't worked I would have gone to my dealer and sprung for a single set of pads just to get a clip.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Whats the purpose of the clips? Are they on both pads/wheel?
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
this is what holds the pad to the caliper puck so it gets pulled back when it retreats after you apply it. It also holds the pad in place so it doesn't go flying out when you try to stop.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Clips
Has anyone measured the diameter of the wire used for the clips? I would like to get some wire in advance of starting a brake job. THANK YOU
The EBC pads no longer come with the clips either. You can only get them with BRP pads.
If I remember right the diameter of the wire I used was .049. I don't remember the diameter of the wire BRP uses but that is close. Like I said before,it is ugly but it works.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
According to William at EBC brakes in Las Vegas the fronts do come with new clips, PN# FA474V and you would need 2 sets. Rears do NOT come with clips.PN# FA473V 1 set.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Yes. they did for a while. Then they stopped. Just got several sets from BajaRon this week, the clips are no longer included. I even asked about it.
Interesting between the time I called and the time you called they stopped. Maybe this was and old box or I guess different employees have different information. All I know when I called and asked they told me yes they did gave me the part # and looked in the box to confirm they were there.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
