Results 1 to 16 of 16
    Sep 2014
    Algonquin
    Default Front brake suddenly grabs on left side only, traction control icon shows briefly
    It happened yesterday, has never happened before in the 3-4 years I have been riding it. Dealer says it shows no codes, and they can get it to do it by starting a turn. It jerks hard to the left for a fraction of a second, then rides norma.lly. You can get it to repeat in a few seconds by startng a turn. 2008 GS 5 speed.
    Bill
    Jul 2011
    Mitchell, Ontario, Canada
    The VSS is confused for some reason. Best guess it's a bad sensor. The most likely culprit is the yaw rate sensor in my thinking. Because no code. Also maybe the steering angle sensor if the calibration is way off. But you should have other symtoms.
    Apr 2017
    North Central Florida
    Quote Originally Posted by silverblack1 View Post
    Bill
    x
    So what does that mean exactly ?
    That even though they can reproduce the problem, they are at a loss as what to do because there are no codes ??
    Default Interesting. ...
    seems that if this can be done only on a turn that there is a problem with the caliper and feed to that wheel. Possibly pads hagging up and not making full contact or something impeding flow to that caliper. As mentioned above check all sensors involved in the stability control system...VSS ABS etc otherwise check the caliper pads and brake lines...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2011
    How could a defective caliper cause the VSS light to come on at the same time?
    Nov 2013
    Central Texas
    Has the brake fluid ever been flushed and changed? On a 2008 it should have been changed four times by now. If not, really dirty brake fluid could be your problem.
    Apr 2017
    Sensor indicates that something is slowing ONE WHEEL, when the computer knows that no braking pressure is being applied.
    Binding caliper, bad wheel sensor or a hose being pinched in a manner that it puts pressure on the caliper.
    Jul 2011
    If the light came on because of a problem there would be a code. No code. The VSS light comes on because it thinks there is a reason to step in and is applying the front left brake.
    Nov 2015
    Chardon, OH
    Yeah. Looks like you're getting an unnecessary / premature activation of the VSS system. The light coming on momentarily is a key, as Billy mentioned. For our later year models, there is a quick and simple Yaw Rate Sensor Reset procedure done through BUDS. You might ask your dealer if that also applies to model year 2008. He may have to look through the manual or fire up the program to see if there is a page for that. If so, I would recommend on doing that first since it only would be a 5 minute job. Checking the brakes - always a good idea anyway.
    Doug
    ”Freedom is not a loophole”
    Apr 2017
    Yes that is possible too.
    But is still is an assumption that may not be true.
    If it IS true, the culprit might be the sensor on the front RIGHT wheel, erroneously reporting that the right wheel is slipping.
    Sep 2014
    Algonquin
    It was just in for a "Brake Failure " warning light, and they changed the brake fluid and adjusted the E brake cable, and lubed the E brake cable. I will call the service dept. with your suggestions. Thank you to all that made suggestions-they all sound good.
    Bill
    Sep 2014
    Algonquin
    The latest: Service department has been in touch with BRP, and have received suggestions as what to look for-this is a unique problem-no answers yet. Is a used one a possibility?
    Bill
    Sep 2014
    Algonquin
    Got the call from the service department-the problem has been diagnosed as a bad VSM-vehicle stability module, with a fix it price including labor of $2800.
    Jul 2011
    Sorry that the most expensive part in the system failed. I thought it would throw a code if it was starting to fail. That's why I went with a bad sensor.
    Sep 2014
    Algonquin
    OK, all fixed-original quote for repair was $2,800 because it needed a new VCM. As it turned out, BRP suggested wiping the memory on the VCM, and re-initializing it. Worked fine, no new parts, just programing. Total cost to fix-$650.
    Jul 2011
    Thanks for this post. I did not know the VCM could be cleared and reflashed. Good to know if someone else has a similar problem.
