DITTO
I'm also not a fan of loud pipes: they tend to aggravate everybody around you...
What the Hell:
DITTO
Originally Posted by AllanSpyder
I also have Akra Straight Shot silencer and cat still in place. I really love the sound, it is louder than stock exhaust, but not too loud. It has a nice deep rumble ...
I found a interesting comparison of exhaust sounds (stock vs Akra + cat on and off) from Youtube:
Allan
Great video. Thanks for sharing.
If I'm recalling correctly, the Stock exhaust with the Lamonster pipe on sounded pretty good. So, if I have the stock exhaust on my F3S, would I just need to purchase the Lamonster pipe? Is it easy to install?
punisher
Originally Posted by Tx web rider
Do you personally own this exhaust?
Yes, you can just buy the Lamonster pipe and run it with existing exhaust. Sound should be quite good. I have my cat still on, so I cannot comment the installation part.
Allan
Yes, and yes - with a spring puller or a piece is string.
Husband has lamonster bypass and stock USA muffler on his Daytona. Great sound. Not as ummmm as akrapovich with bypass. Noticeable but not offensive.
In oz, stock muffler for the f3s is the rt muffler, not the nice short USA stock one. If you want quiet, that's a way to go.
Originally Posted by Dave7691
I put an HMF pipe on my F3-S and liked it , but it was a little harsh . So I put a QQ Big City Thunder baffle in it and for me it took the harshness away , it now has a deep tone and pulls real strong all the way thru . For me l love this pipe deep throaty when your want it to be and great when cruising .
I put the Lamonater cat delet pipe on Cindy's F3S and she loves it but I put the QQ Big City Thunder baffle in it .
How easy was it to do the replacement? How long? Any special tool? Can a non-mechanic do it easy? Any challenges in changing it over ? Can you replace the original if you sell the bike and want to keep it ?
Install
Very easy to install , the hardest part is the top spring . I used some nylon string and used a screwdriver to make a t-handle and just pulled them off . Sprayed the rubber bushings with silicone . Lossened up the front clamp an pull the cat off . I did one by backing up a car ramp and jacked up the first one hope this helps . I did keep all the OEM parts to put back on when selling .
Allan
What do you mean by run it with the existing exhaust?
Have any pics?
Have any pics?
I meant that you can keep the stock exhaust and just install the Lamonster bypass. Here is the product link: http://www.lamonstergarage.com/perfo...ent-pipe-1330/
Allan
This thread is all over the map and is mind boggling. I'm staying stock. Red flags should go up when you watch Lamonster's video where he says, "This part is recommended for off road and tuning and testing purposes only." Quite a disclaimer. A little bit of legaleze going on there.
John F.
Tallahassee, FL
2015 Spyder F3 SE6, black
BRP Driver/passenger Footboards
BRP Adjustable Passenger Backrest
Blue Ridge Windshield
MRA X-Creen Tour, clear, clamp-on
H4 LED Headlights
F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
Easy Brackets
Leatherworks, Inc. 120 Special Slight Angle Saddlebags
Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
2-up rear shock
Idler pulley kit
Originally Posted by bmccaffrey
My opinion there is not any muffler that sounds good on the 1330
At least that i have heard
I agree--I took the Cat Delete back off & reinstalled the Cat.--The AKrapovic with the Cat sounds great to me...
Interesting... How does the "Akra" sound on the F3, with the catalytic converter still in place?
I'm not a fan of "louder", and I realize that "better" is a completely subjective yardstick...
But it IS fun to look for an improvement!
Sounds perfect to me--I had the Cat delete installed with the BRP Akrapovic chrome straight shot--it was too loud for me plus it lost low end power. I reinstalled the Cat with the Akrapovic & it's exactly what I want. I even tried installing two (2) baffles with the Cat delete & it sounded terrible--not just loud--loud plus terrible :-(
that would be on the 2008-2012 they are very aggressive.)n the 1330 RLS Exhaust has a few option for great sound and performance look at the Full exhaust options i have on rlsexhaust.com use one of my cat delete pipes with the 2 stage baffles and accompany it with the Crusher series exhaust for a great sound and look .469-878-5166 if anyone has questions 2 videos attached one with just the exhaust and the has the cat delete and exhaust installed
I just want my exhaust loud enough to cover all the pops,bangs,clunks,whirrs that the 1330 makes, noisy beast.
2018 F3 , Full size brake pedal Black
Allan
I have the same Akra Chrome straight shot with CAT still in place--it makes a nice rumble backing down thru the gears. The CAT bypass was obnoxious & adding 2 bables sounded terrible. My neighborhood is much happier after I re-installed the CAT. I think it was Jase that said removing the CAT adds "mouse power" to upper rpms but it lost a ton of torque off the line.
