So last week went to Myrtle beach with it. All was fine riding it. We were in stop and go traffic and revved it up and was just having fun. Thenthe throttlw got stuck and had to turn it off. Wouldn’t crank back up. Towed it home. Still wouldn’t crank. Sound like it wasn’t getting fuel. Check the one spark plug that is easy to get to and fully charged the battery. It then cranked up. Ride about 30 mins and it died again and when cranked back up it just sounded different and I smelled gas. Also was very sluggish and didn’t want to get out of second gear or gonpast 50mph . Of course no fault codes came up. One dealership said for $105 a hour they will plug it up and say what’s wrong. Another dealership said sounds like “limp mode” he said modifications could be doing that. So how out of no where my mods do this? I have the 2 brothers dual exhaust and the juice box. So tomorrow I’m taking out the juice box and putting in the NGK iridium spark plugs. Hopefully it will run right then
I don't have an RS so I don't have any words of wisdom. However, I am sure that there will be some good folk that come on with advice. Is the bike new to you and do have any maintenance history for it? I would search the archives of this site and try to find a reputable dealership in your area to run the bike through a full assessment. it may be something simple like vacuum hoses or a combination of things that need some attention to get you back on the road. Good luck and have faith! Like the color of the bike by the way!
I have not experienced this nor read about it, but my Spyder Sense, pun fully intended, is telling me that the vacuume hoses and accompanying rubber tubing is in need of repair and replacement.
But then that is just one real consideration that I would check. The iridium plugs and a K&M air filter won't hurt you a bit either.
Why does everyone think it’s a vacuum hose? No one thinks it could be the two brothers juice box since the spyder is sensitive ?
I have a GS with dual Two Bros and a juice box. It's a great combo.
The vacuum hoses will deteriorate after a while, get cracks in them. Replacing them with new silicone hoses is a cheap, easy and long lasting fix.
While you're replacing the plugs, be sure to replace the wires too. The OEMs become embrittled after time and start arcing and sparking. BahaRon's spark plug wires are the best out there.
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
..... Considering the age of the Spyder this is where I would start .....and for the most part less than great dealers LOVE to Blame any after-market item on the Spyder as the CAUSE ..... A BUDS print-out of any codes that are in the computer is very helpful ..... But it would really take about 15 min. max. to get that print-out ....Sooooo they are charging you $ 432 hr. labor .....good luck,...... Mike
Not only the vacuum hoses can be an issue, but the boot between the throttle body and engine can develop cracks and let in unmetered air. If you tear it down to replace the plugs, check those two areas. Just had a friend in Alabama go through that with his 998. Doing pretty much the same thing.
Well already bought the plugs. Bike has $7k Miles on it. If it’s this dang fragile then ppl need to stop buying them. I’m in process right this second in unhooking the juice box and putting new plugs in. No didn’t think of buying wires also. Will keep you posted. Top of air filter box wasn’t hard to remove
Took out the 6 screws around the throttle bodies and lifted in the air box up. Spark plug didn’t want to come out but finally did. Thing cranked and ran fine. Sputters some but runs great
This WILL help.
Sorry to hear about your problems. My 2009 was a dream come true. I loved it. I will sy, I bought it new and did some radical changes (at the time). Check out my website and see my Yellow Bee. BTW, I'm offering free freight for the rest of March. All you need to d is email me rather than ordering thrum website...that's a $445. savings.
Ride in comfort.
John
They look fine to me and this spot here two came off different sizes
Being you have the the bigger one off might as well change it too. The 2 smaller hoses are the ones they are talking about. Real easy to get to with the air box off. Mine was missing also like yours and found a bad plug wire. It would sometimes arch out of the boot and you could see the spark. Once I replaced the wires all was fine.
David
David
Ok the hoses look perfect so put them back on. Then checked the spark plug wire on the difficult side and BAM it’s arcing. So that HAS to be the problem lol
If it is doing that you have found it. Mine was acting crazy almost like it was running out of gas. I would put new hoses on instead of the old ones. If you have a NAPA store around you get this for the 2 hoses https://www.napaonline.com/en/search...ue&indices=PIA
David
Ron has some good plug wires. For a temporary fix you can wrap the boot with electrical tape and that will allow you to ride some while waiting on new plug wires. Only use this as a temp fix. I did the same thing while waiting on plug wires to come in.
David
David
... Sorry but that doesn't " HAVE to be the problem " ..... I don't understand why you seem to be ADAMANT about refusing to change to Silicone tubing .... Do you really feel everyone who has identified this as a KNOWN issue is BS'ing you ...... Or do you feel that the OEM tubing is going to last forever , so spending $1.50 for new silicone tubing is a waste of time and money ...... I fail to understand your logic on this ............. Mike
Easy Mike, you know the old saying, you can lead him to water but you can't make him drink!
