Page 1 of 4 1234 LastLast
Results 1 to 25 of 95
    Invalid Emails
    Apr 2014
    Northwood NH
    Default 215/60R15 Michelin Hydroedge wear report
    New tread depth .360
    Tread depth after 2500 miles .330
    difference .030
    Estimated life .360 / .030 * 2500 = 30,800
    So far tire handles nicely and good in rain
    Aug 2013
    Quebec City, Quebec
    Best replacement rear tire for Spyder. I have one and very happy with it.
    Default Good to know..!!
    thanks for the update.
    United States
    Just bought one for $85 off of Amazon. Best price I could find!
    http://www.amazon.com/215-60-15-MICH...ELIN+HYDROEDGE
    Jun 2011
    Lynden, WA
    Do you have a picture of it on the bike? Just wonder how it looks compared to stock dimension wise.
    Thanks,
    Randy,
    Quote Originally Posted by sddinnh View Post
    difference .030
    United States
    What pressure have you found works best for this tire?
    Aug 2012
    Central Coast, CA
    difference .030
    Interesting. Thanks for sharing your experience. That tire has a hardness rating of 800, with a 90,000 mile warranty. This rating being near the top end of the compunds available. Since the Spyder is so light relatively speaking, it seems like it could cause some handling issues.
    2020 RTL SE6
    Aug 2013
    Quebec City, Quebec
    Quote Originally Posted by KX5062 View Post
    No handling issues since I install my Michelin HydtoEdge on my RT.
    Nov 2012
    North Las Vegas, NV
    We have the same size Primacy, no issues whatsoever.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    United States
    Quote Originally Posted by tigerdr View Post
    What pressure are you running??
    Nov 2012
    North Las Vegas, NV
    ImageUploadedByTapatalk1408762682.081200.jpg[ATTACH]93687[/ATTACH Here's mine.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Aug 2013
    Quebec City, Quebec
    Quote Originally Posted by Doc Humphreys View Post
    28PSI. I have a RTS.
    Invalid Emails
    Seneca, SC, United States
    Thumbs up Hydroedge
    difference .030
    Thanks for the information, I just ordered two to us... Found out they are being discontinued so I wanted to stock up.
    Michael
    Invalid Emails
    Apr 2014
    Northwood NH
    I'm running 28 psi also. Tread wear looks nice and even. No handling issues that I can report. I'll snap a picture when I get home tonight.
    Invalid Emails
    Apr 2014
    Northwood NH
    You were my inspiration to go looking at this size. Your good luck with the Primacy caused me to hunt around and I found the Hydroedge. Too bad they discontinued it, but I have a spare in the basement
    Nov 2012
    North Las Vegas, NV
    As long as it works, that's what counts. I'm running 28 psi as well.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Invalid Emails
    Apr 2014
    Northwood NH
    Default Michelin Hydroedge
    Here's the Hydroedge at 3700 miles - nice and flat with good tread definition. You can see the heavy center rib and good water paths to the edge which is one of the reasons I chose to try this tire
    Aug 2013
    Quebec City, Quebec
    Michelin HydroEdge or Michelin Primacy... the best choice.
    United States
    Here's the Hydroedge at 4000 miles - nice and flat with good tread definition. You can see the heavy center rib and good water paths to the edge which is one of the reasons I chose to try this tire
    That looks awesome! Can't wait to get mine installed!
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Good Info like formula 1 harder compound will last longer but is not good in the rain asked another SL he said his michelin hydroplanes he is using the same tire , lower treadwearwear tire will be softer better for rain
    Invalid Emails
    Apr 2014
    Northwood NH
    Quote Originally Posted by jtoro1 View Post
    All I can tell you is I've had no problems with this tire in either the wet or dry. I would like to know what kind of Spyder did have a hydroplaning problem. I'm running this on a 1000# plus RT-L and if you put the same tire on a lighter RS or ST then I have no idea how it will re-act, but that may account for the difference.
    Jun 2011
    Lynden, WA
    I have never heard that softer rubber is better for wet roads, only for traction. Is this fact?
    Nov 2012
    North Las Vegas, NV
    Hydroplaning has little to do with compound, it has more to do with tread pattern and how the tread sheds water. If that were true soft slicks would be great in the rain. If you want to run a soft tire go ahead but some of us don't want to change tires twice a season.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Aug 2013
    Quebec City, Quebec
    The Michelin HydroEdge was designs to be the best tire on wet road. This tire was severly tested on different wet condition and hydroplanning.
    I drive today under heavy rain and on rough pavement. No hydroplanning with this Michelin HydroEdge. 24000 kilometer (14000 miles) on this tire.
    And how is it holding up to the extended use? How much tread depth do you still have?
