The list of affected keys...
gain, this is just to help out. It seems some have received incorrect info. There are a lot of key tags on the list. If you lost or discarded of your key tag and your vin is on the list you still need to have it checked. Here is a list of the key tags that are affected. 1656 1750 1800 1900 2009 2163 2200
1657 1751 1801 1901 2010 2164 2202
1658 1752 1802 1902 2011 2165 2203
1659 1754 1803 1903 2013 2166 2204
1661 1755 1805 1905 2014 2167 2205
1662 1756 1806 1906 2015 2169 2206
1663 1758 1807 1907 2017 2170 2208
1665 1759 1890 1908 2018 2171 2209
1666 1760 1891 1909 2019 2173 2211
1667 1761 1892 1910 2020 2174 2212
1668 1762 1893 1912 2021 2175 2213
1669 1764 1894 1913 2023 2176 2214
1670 1765 1896 1914 2024 2177 2215
1671 1766 1897 1915 2025 2178 2217
1673 1768 1899 1917 2027 2180 2218
1674 1769 1918 2028 2181 2220
1676 1770 1920 2029 2182 2221
1677 1771 1921 2030 2183 2222
1772 1922 2031 2184 2223
1773 1923 2032 2185 2224
1774 1924 2033 2186 2226
1775 1926 2034 2187 2227
1777 1927 2036 2189 2229
1778 1929 2037 2190 2230
1780 1930 2039 2192 2231
1781 1931 2040 2193 2232
1782 1932 2041 2194 2233
1783 1933 2042 2195 2235
1784 1934 2043 2196 2236
1785 1936 2044 2198 2237
1787 2046 2199 2239
1788 2047 2240
1789 2048 2241
1791 2050 2242
1792 2051 2243
1793 2052 2244
1794 2053 2245
1795 2054 2246
1797 2056 2248
1798 2057 2249
2059 2251
2060 2252
2061
2062
2064
2065
2066
It appears that 1760 is on the list.
Bob, Where can I find a complete list of " Key Tags #'s? Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Originally Posted by billybovine
That's correct Bob.
The 2014's have 2 different problems with the ignition and keys.
Problem one. Ignition switches with a certain series of key codes will get stuck and need to be replaced. The code is on the rubber tag that came with the keys.
Problem two. The spyder is unable to communicate with the transponder key. The DESS unit needs to be replaced.
They are two unrelated and separate problems with two different solutions. Over time they have been mixed up and confused. The result is people like the OP get lousy and confusing advice.
Billy, The D.E.S.S. unit is under warranty I had the D.E.S.S unit replaced on my 14RT-SE6 last week. Also, the dealer had to reprogram the both sets of keys. Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
HI Dee,
Your dealer could bring it up for you. This list was posted back late in the Winter of 2014, when this issue popped up.
Your keys came with a small "tag with them. It's probably on the keyring that holds your spare key and sheath.
It'll have a four digit number on it. If it's on this list; you should have your dealer take action.
(This is completely unrelated to your recent warranty work...)
UNDERSTANDING WHAT YOU READ
One problem is unrelated to the other; I just don't know why you'd ask about it?
HI Dee,
Hi Bob, The next time I visit my dealer I will ask. Is this a separate problem? Should I wait ? Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
If you've had no problems with your ignition switch appearing to "jam"; I would say that it's not a critical issue. It'd be more just for your peace of mind!
If you can look up that number on the tag, and compare it to what I posted above; that'd give you a good idea of if your bike might be affected.
The service desk is telling me the VIN/key tag combination is NOT on the service bulletin. Right now they are pulling the switch out. They believe something is physically preventing the key from being fully inserted.
See list on post #26. 1760 is there.
OMG
My curiosity is killing me. How'd you get the parking brake released?
The tow driver used my crescent wrench to loosen and then release the cable at the rear wheel.
I know. They are telling me both the tag number and the VIN need to match.
When the recall happened back in early 2014 my key tag match but the vin did not . I was having the same problem as you and my dealer got it replaced under the recall.
Bob
The back and forth he said she said arguing is not helping the OP!
Just say'in....
Bob
I agree . There are two separate problems. 1. the dess code and the computer chip. this is the recall that fixed mine. 2. the fact that he key does not turn is a whole new issue and they are not related.
I cannot find a copy of the TSB but if I remember correctly it has nothing to do with the VIN. It's key code only. Maybe someone could find a copy of the TSB and post it.
I hope they get you on your way soon.
KEY
My 2014 RT did the same thing and was not on their list.Got it dealer he took the key and filed the bottom tip off on both sides of the key.Has worked perfect for over a year.That is what BRP had on their computer as one of the fixes.
I checked into a hotel last night here in Daphne Alabama. I'm riding my 2014 Spyder on a tour of both coast. This is day 13 of a 27 day ride.
This morning my ignition is frozen. I can insert either of my keys but neither will turn. I tried WD40 with no luck. No sign of damage to the lock, and the cover was still in place this morning so I don't think it was tampered with.
Here are my questions:
1. Dealer recommendations in Mobile area?
2. Is there a way to manually disengage the parking brake so I can get the bike on a tow truck?
3. Any other quick remedies I could try?
Rod
This is why I now ride a Yamaha. No flames please - I'm not trying to be nasty - just telling it like it is.
Not attempting to flame ya, but I'm not sure I'm following you....
Are you saying that you ride a Yamaha because they are trouble-free? Yours might be the first....
I'm back on the road. The tech from Hall's Motorsports worked through the afternoon to replace the switch. I'd like to thank them for making me a priority and thanks to all of you who contributed to this thread. I'm 1/3 of the way through my trip. Now it's on to California, up to Washington, and back to Ohio!
Congrats, glad you are back on the road and hope you have a safe and enjoyable trip.
Toby
2020 RTL
Yes, congrats on getting back on the road. Be safe!
