Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Invalid Emails
    Mar 2011
    NE TN
    Default Flag holders for Patriot Guard 3 x 5 Flags
    Quote Originally Posted by KAPike View Post
    Here's a couple pictures of the final product
    Here's a couple pictures of my office where I get a lot of thinking done at 3AM.
    Kraig
    I like it. Is the flagpole SST railing also?
  2. #27
    Jun 2011
    Aransas Pass Texas
    Default 3x5 flag mount
    i purchased the can-am spyder compatible trailer hitch on ebay works great i put a 4 foot section of all thread that fits tight inside my flag pole and double nutted it on the hitch where the ball goes works great
  3. #28
    Aug 2012
    Bridgman, Michigan
    Quote Originally Posted by Yol Bolsun View Post
    The whole thing is Stainless Steel except the bolt going through the Spyder hitch. I think the mount is 3/4 bow rail and the flag pole is 1/2 bow rail. I put some white tape around the flag pole to center the pole more and cut down on the sloppyness.
  4. #29
    Mar 2012
    Beaverton, Oregon
    I may have solved my flag holder. I just bought a Pakit Rak and the hitch adapter looks as though it may work great.
    Two birds with one stone!
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
  5. #30
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    Quote Originally Posted by bmwlarry View Post
    That looks cool but what looks cooler is what you did with the trailer cable. Great idea!
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
  6. #31
    spacetrucker
    Guest
    Now make a been in the steel up and will look good. The way you have it now is to much down and out so been it up and will look great. Oky
  7. #32
    spacetrucker
    Guest
    Call me later in am ok about flag holder got some steel that might work square steel.
  8. #33
    Invalid Emails
    May 2012
    Campobello,SC
    Default PGR Flags
    I have joined the Patriot Guard. They use the large 3x5 ft. flags fro their ceremonies. Does anyone out there participate in the PG and what flag mounts do you use to hold the large 3x5 ft. flags securely at low speeds?
    I'm a PGR and have a homemade two flag mount on my RT trailer hitch. Only I don't use 3x5 ft.
    flags, I use the smaller 2x3 ft flags mounted on 1" EMT. It's quite stable, even at higher speeds.
  9. #34
    Mar 2013
    Prairie Grove, AR
    Default Flag Mounts
    Quote Originally Posted by shrubs View Post
    I had a set made for my Wing (See below). They should be able to hook to about any ball hitch (less the ball) as I've used them on truck's reese hitch. I pick up my hitchless spyder tomorrow. It wont' be hitchless for long. The price isn't for the faint of heart though. I have run these on my Wing at 80+ (with police escort) and never had a problem or ever worry about them.
    They are cast and come about in three sections via quick pins.
    I bought them in '10 so I'm not sure if they are still making flag poles and mounts.
    The contact info is:
    M & M Machine Services
    P.O. Box 548
    Paris, IL. 61944
    Ask for Kevin (mmmachine@comwares.net) and let him know your with the PGR.
    Note: I buy all my US and military flags from Eagle Mountain flags in Texas (http://www.eaglemountainflag.com/) as they are made in the USA.
    they do not seem to be in business. Do you have a current email/ph number for M&M?
  10. #35
    Oct 2008
    Barstow, California
    I’ve been using a Rivco pole mount. It’s on a 1/4 x 2 x 4 plate that has a slight offset bolted with the hitch ball stud. The pole mount is not 90 degrees so old glory must go down the freeway at an angle. I use a 1 in metal conduit as the pole and use tag lines from an eye bolt on top to the rear grips as a back up in case the pole comes out on rough roughs with the swing arm action. I do have the pole secured with a keeper pin but bolts and welds have been known to fail before. Where are you buying your flag. A flag made strong enough for high winds is a must. I’m on my 5th flag already from a company down the freeway that sells them to local schools, etc. I live in an area with high wind activity and when you’re traveling into the wind at 60 plus mph they don’t last long. I also have a flag that’s like a net which has been my best. I need to get it sewn up because it’s seen some action a bit. It’s legal to wash and repair the flags btw. I’m a RC in SouCal which is one of the busiest in the country.
    Happy Spyder Owner
