. These are called (Tomar Rect-13LS) Tomar Intelligent LED Series. They have a programmable internal flasher with 20 programs. use just shy of 0.4 amps at 12volt.
Those look great. I have been looking for something like that. They look really bright - would you say that they could be too bright? I am looking for something that bright but not bright enough to "blind" the driver behind me.
These are the same mini LED lights used on Undercover Police vehicles. They are SUPER Bright and dependent on the position u mount them,they could cause the driver behind you to see spots. I have them mounted in just about the right location so as to Gain Formidable Attention and Be Seen. I have a set on my GL 1800 and I was told that they are almost blinding from behind. I love to make sure my wife is seen when she's coming to a stop. We've noticed people stop a lot further back from us when they see the lights come on.
IN my state, brake lights may strobe a maximum of 5 times before they go solid. People stop farther back because they don't know what they are coming up on. Don't be surprised if a police officer stops you and has a "talk" with you about what is basically a strobe light instead of a brake light.
If I am seeing it right, the light hanging above the rear tire won't last long as a good bump or dip moves the swing-arm and the back tire/fender up to almost touching the bottom where the light is mounted. I put side cases on my RS and the kit moves the blinkers down to the rear fender and I thought I would be smart and put an extra brake light between the blinkers. Made the first road trip and noticed the brake light had hit the above part and it was broken! Below is a picture before it was broken.
Well she's put over 1000 miles with those lights on there, and hasn't broke them off yet... So it seems her STS suspension doesn't move that much. I've followed her and that suspension seems to stay at least 4 inches or better from hitting the light. We've already chatted with multiple Po-lice and there's not an issue with the rate of flashes or type of lights. They are just happy that they aren't swirling...definitely gets noticed for sure.
Can they be set to flash a certain number of times then burn constantly?
I purchased this tiny module and installed one on my bike and my cars' third brake light
It is adjustable for both speed of flashing and number of flashes before it goes solid
Hmm.. the light sticks and some of the minis - can they be used as aux running lights up front (in white, of course)?
Sold List: 97 Ninja500R, 03 SV650K3, 01 Ducati 750Sport Dark, 73 CB350/4, 03 F650GSA, 08 Gixxer600, 03 Gixxer600, 91 VFR750F, 09 KLX250, 06 Thruxton 900, 08 Spyder RS , 12 Street TripleR, 15 RC390, 02 VFR800, 09 KLX250S, 10 F650GS JLohPhotos
Sad that you even need items such as these. If only people paid attention.
they are there cell phones. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
