Results 1 to 18 of 18
Thread: Ready to Buy
    North East
    Default Ready to Buy
    OK folks. Been patiently listening and learning for about 6 months now. About to pull the trigger. Choice is between 13 and14 RS SE. I have been able to get the price on the 13 way down but I told him he will have to get BRP to swap out side panels to address the heat/fuel issue. Is there anything else I知 missing? I remember talk awhile back about ignition issues and a list of serial numbers to check. Did that include the 13 RS?
    What about Laser Alignment. Do folks lean towards one if they have issues or just because it really makes a difference? Found someone in NH that has good reviews. Love this site!
    Mar 2013
    Quote Originally Posted by NorthEastJ View Post
    The dealer should have all the updates done on the 13, but make sure you ask. Have the new panels installed before picking it up is a great idea. As for laser alignment I would recommend it as very few Spyders come form the factory correctly aligned.
    Congrats on your new Spyder (which ever one you get) and please post pictures when you get it.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Default You got it..!!
    the dealers should have all the recalls etc done but check the panels. Ignition was not an issue on the RS so if they are getting a good price go for it....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2008
    MA & NH
    Default Congrats
    and welcome.
    Registered Users Ronbo's Avatar
    Mar 2013
    Arkansas
    Default Pullin the trigger....
    What is the price? I have a 2014 RT limited for sale, 1330 engine...might be able to get close to price.
    Ronbo
    It sounds like you have done due diligence. Yes, on the new panels for the 2013. Get them before you drive off.
    Post some pictures.
    Jun 2010
    Las Vegas
    I didn't know there were swaps for the RS panels, I only thought that pertained to the ST. I haven't heard anything about the 13 RS being any hotter than any of the other years.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Registered Users Rockwall's Avatar
    Jan 2013
    Northern Illinois
    Sounds like an updated 13 is the best deal.
    2012 Spyder RS SM5 - Steel Black Metallic "The Murder"
    Southern Cruisers Riding Club - Chapter 072 - Northern Illinois
    Two Brothers M2 Pipe; TB Juice Box; Hartco Custom Saddle; Rivco Driver Floorboards; Rivco Heel Toe Shifter; ESI Highway Pegs & Brackets; ESI 4.5" Easy Riser Handlebar Risers; BajaRon Sway Bar; Cycle Sounds Series 3 200 Watt Sound System; 14" Touring Windshield; Custom Dynamics Mirror Extensions; Kuryakyn ISO Grips; Kuryakyn Throttle Boss; Kuryakyn End Weights; Frunk Liner.
    Nov 2014
    FL
    First of all Welcome to the forums and congratz
    Vermont
    and on your new ride. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Now for the FUN part... choosing the right ride!
    Active Member hdlongrod's Avatar
    Houston
    You are correct.
    His - 2013 RSS SM5
    Hers - 2013 RS SE5
    Proud Army Veterans!!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    The RS 2013 was the model where they went to having a separate CAT under the bike, the earlier models had the CAT built into the exhaust. I have heard that this did cause some increase in heat, though not to the extent of other models.
    Unfortunately the '2013 Spyders run hot' view has tainted the RS even though other models where the ones most affected. The RS 2014 came out with the new vented panels, I suspect this was to allay comments on heat issues.
    One Australian RS 2013 owner did comment on how after fitting the new panels they found theirs ran 1 bar lower on the temp gauge - however they said they also had more noise and buffeting than before.
    Jan 2015
    southern WI
    Default Soon to be an owner
    My wife and I did some initial paperwork on a 2010 RT-S last week. It looks like it's gonna be a done deal by the end of this coming week. I'm pretty excited as she is as well. So, I've been a lurker here for several months, but I really don't see much on the 2010 RT. The dealer says all the updates have been done on it. Was there anything that should jump out at me with this model?
    2016 RTS , Pearl White
    Very Active Member spyderbirds's Avatar
    Apr 2011
    Bowling Green, FL
    Quote Originally Posted by MZEMS2 View Post
    We have 46K mostly trouble free miles on our 2010 RT A&C. Replaced two stock rear shocks before switching to Elka. Also had the DPS unit replaced under the BEST extended warranty.
    2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
    2014 XLR Viper 305V14 Toyhauler (Home)
    2015 Ram 3500HD Crew Cab
    Former Spyders
    2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
    2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
    Dec 2008
    Jacumba, CA
    We have a 2010 RT SM5 BareBone. The major issue was a bad Throttle Body, which was warranted, but never left me stranded before it got changed. I learned how to make it work, with patience. Also had the muffler replaced under warranty...baffle issues. Hums like a humming bird. Almost forgot...mileage approaching 55,000 miles all put on by me.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Oct 2013
    Tyler, TX
    Default Price is only one consideration, don't ignore the performance
    I traded my 2013 RT LTD with only 3300 miles for a 2014 RT LTD and even though it probably cost me $8000 I do not regret the purchase. Certainly the heat was a big motivation but the biggest difference is the ride quality. On the 2013 I always felt like it needed the 6th gear. I got used to the high rpm's but it did not feel natural.
    Make sure you ride both units. Either way, you will like the spyder experience. Unfortunately, I fear you will regret the purchase of a 2013.
    Just my opinion and not intended to offend current owners of 2013's.
    Oct 2013
    Tyler, TX
    Default OOPS! Wrote about RT, not RS, please disregard comments
    Quote Originally Posted by wcricks View Post
    Sorry, I did not realize you were considering an RS, not RT. I have no knowledge or experience.
