Results 26 to 50 of 65
  1. #26
    Oct 2015
    Lynden, WA
    Thumbs up Mods for STS
    Looks clean and complete. Much better than the flat iron of the
    original saddle bag mounts.
    Nice job.
    Cheers, David C.
  2. #27
    lake mary fl.
    Great mods. I think you're going to be a grate asset to this forum!
    LOVE IT WHEN SOMEONE IS NOT AFRAID OF GETTING BITTEN BY A SPYDER!
  3. #28
    Apr 2016
    Tennessee
    is it just me, or is there a considerable amount of talent here on this board. I wish I had the mind to come up with some of the stuff you guys do...Wow...just WOW
  4. #29
    Very Active Member JimVonBaden's Avatar
    NoVA
    And add a little powder coat:
    Next is to add aux turn signals on the panniers before I button it all up.
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
  5. #30
    NoVA
    Rewired up the lights adding turn signal strips for better visibility, then reassembled it all with loctite.
    Wiring:
    Assembled and tested:
    Jim
    2013 ST-S (wife's)
  6. #31
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    NIce work.
    Live, Love, and Ride! God Bless!
  7. #32
    NoVA
    OK, now that the majority of the mechanical mods are done, a little cosmetic to go with it. The pannier panels were black, and the top case panels were flat silver. Time to make them look the part.
    Original Painted panels:
    Add a bit of primer:
    Coat one, then two of color, then two coats of clear.
    I'm going to let them dry overnight, then install them tomorrow.
    Jim
    2013 ST-S (wife's)
  8. #33
    NoVA
    And finished. I think the color match is dead on, and the shine pretty good. I have to let the paint cure, then I can polish it to a mirror shine. Then I have to polish the rest of the bike to match!
    Jim
    2013 ST-S (wife's)
  9. #34
    Very Active Member armyspydervet's Avatar
    Nov 2015
    Occoquan, VA
    That looks great!! You're hired! I'll be contacting you when I'm back in town
    Chris
    2016 F3-T SE6
  10. #35
    NoVA
    Quote Originally Posted by armyspydervet View Post
    Thanks, I look forward to meeting you.
    Jim
    2013 ST-S (wife's)
  11. #36
    Sep 2008
    Yorktown, VA
    Great job Jim! Where did you get the paint from?
    Bruce
    Yorktown, VA
    '08 Spyder GS
  12. #37
    NoVA
    Quote Originally Posted by bwbarnes View Post
    Thanks, it came out well.
    http://www.colorrite.com/product/can...allic-2480.cfm
    Jim
    2013 ST-S (wife's)
  13. #38
    NoVA
    I added a dual zone Heat Troller to the ST-S today. I like to control the gloves separate from the jacket. I also added waterproof plugs for both with it. I used a replay so they would go off with the key.
    Jim
    2013 ST-S (wife's)
  14. #39
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by JimVonBaden View Post
    Does that work gerbin clothes and where did you get them?
    thanks, David
  15. #40
    NoVA
    Quote Originally Posted by Warlock View Post
    thanks, David
    Gerbing, Warm & Safe, First Gear, nearly any manufacturer uses these plugs, and the Heat Troller works with all of them. I have a First Gear Jacket and Gerbings gloves, and they use the same connectors.
    I get this kit here: http://www.warmnsafe.com/dual-mounte...ler-old-style/
    I have this kit on my BMW and have installed at least a dozen of them on a variety of bikes.
    Jim
    2013 ST-S (wife's)
  16. #41
    Oct 2011
    Magnolia, Ms
    Thanks for the website.
    David
  17. #42
    Sep 2014
    scranton, pa
    Default ???
    Also, because I have a set of heated grips to install, as well as aux lights and a USB power plug, I pulled the panel and added the switches. The Heated grips plug is there and went right in. I pulled the hot and ground from the second from the left socket for the USB, and the Aux switch seemed about right so I plugged it in. I wont know on that until the lights come in.
    More to come when the rest of the parts come in and I have time.
    where did you get the usb plug ??
    2013 sts , Pure Magnesium
  18. #43
    NoVA
    Quote Originally Posted by spyderjeffrey View Post
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Works great.
    If you use the orange plug, it is for air suspension I think, and the red and black wires have switched power and the right connectors if you pull them out of the plug, it is a dead easy install.
    Ignore the Posi-Tap. I am using that red hot wire to activate a relay for my heated gear, also.
    Jim
    2013 ST-S (wife's)
  19. #44
    Jun 2014
    Schenevus NY
    Great thread Jim. I'm going to shamelessly rip-off what you did when I install my new driving lights over the winter.
    Major sir!
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
  20. #45
    NoVA
    Quote Originally Posted by Trbayth View Post
    Major sir!
    No shame. We all learned from someone else at some point.
    Thanks!
    Jim
    2013 ST-S (wife's)
  21. #46
    Linden, CA
    Default All I can say is
    Fantastic JOB... I like your bags better than my Givi bags and I like the mounts better.
    Way to go on your project.
    Dave
  22. #47
    NoVA
    Dave
    Thanks Dave. My wife really likes how they look. They are quite functional as well.
    Jim
    2013 ST-S (wife's)
  23. #48
    Jun 2014
    Schenevus NY
    So after a couple of weeks have you had any problems with that USB port? I read the reviews of it on Amazon and a couple of people mentioned it wasn't suitable for USB-C applications as the internal components aren't up to the advertised rating.
    There's also a variation that includes a voltage readout between the USB ports.
    Trb-- (Roger)
  24. #49
    NoVA
    No, no issues. It works well in the rain too. I suspect their issues are more with their devices. Some, especially iPhones, don't work well with non Apple USBs.
    Jim
    2013 ST-S (wife's)
  25. #50
    Dec 2016
    Cleveland, GA
    Default Switches
    Interested in obtaining the Heated Grips & Usb switches. (source)?
