Results 1 to 4 of 4
    Active Member Pallidus Aranea's Avatar
    May 2018
    Eastern Shore of MD
    Default Lift / Hauling Question
    We are in the process of preparing to "go on the road" for a few years. Currently the 'rig' setup is a 45' Tiffin Coach and my Veloster in tow. I have seen a few coaches with a dual motorcycle lift on the rear and towing a car.
    - Is there a motorcycle lift that will accommodate the Spyder?
    I know that the weight is not an issue but the 'y-layout' can be. (In fact it such a problem that freakin' Amtrak no longer allows Spyders on the 'car train')
    Thanks in advance for any advice you have.
    Dave
    "Pallidus Aranea"
    (Pale Spider)
    • 2018 CamAm Spyder RT Limited - Pearl White / Chrome
    • 2008 H/D VROD 105th Anniversary Edition (665 of 1200) - Retired
    • 1987 Honda CRB600F - "Hurricane" - Retired
    "Any intelligent fool can make things bigger and more complex… It takes a touch of genius – and a lot of courage to move in the opposite direction." - Albert Einstein
    2018 RT Limited , Pearl White
    Default Not sure....
    but you can try something like this....
    http://hydralift-usa.com/canam-spyder/
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    If you use a lift like this it may be too wide. Motor-home is 102" wide, spyder is 105" add some room for the lift and you may be oversize.
    https://youtu.be/lAl6IgRPUvU
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Feb 2018
    NorEastern, Washington
    Quote Originally Posted by Pallidus Aranea View Post
    Dave...
    Take your trike and the car. Less weight added to the back of the MH. They make with platform up to 10'long. You can also use a 6' platform and run Spyder side to side and i
    f length of Spyder is an issue, just angle it up a little to get to the 102"
    http://tandem-tow.com/index.html
    OR an extension. Just remember that some states have laws as to how far you can extend from the center of your last braked axel. Washington is 15'. Again, if length of Spyder is an issue, just angle it up a little to get to the 102" width of MH.
    http://www.cruiserlift.com/id77
    Regards,
    Don
    2017 F3T , Triple Black
