Results 1 to 7 of 7
    Invalid Emails
    Mar 2017
    Frisco
    Default WTB Small trailer for Spyder.
    Small pull behind trailer for Spyder. I do not have a hitch yet. May even entertain looking at the one wheeled unigo.
    Jun 2015
    Hampton Roads, VA
    Default Harbor Frieght
    $280ish on sale. Takes about 2 hours to put together. Pulls nice, better with some decent weight, will bounce around empty when you hit a small pothole! Your choice on hitch, I went with showchrome hitch & wiring as I won't be pulling trailer but 2-3 times a year. I couldn't spend $4K on a BRP trailer (wife would shoot me).
    May 2016
    Grand Prairie, TX
    Default Get the Harbor Freight Trailer
    Quote Originally Posted by Geezer001 View Post
    I bought the HF trailer with no regrets. Pulled to Spyderfest last year and just hummed along at 70 mph.
    2015 RT Ltd SE6
    Intense Red
    BaJa Ron Torsion Bar
    BaJa Ron Shock Adjusters
    Premium Driver Seat Back Rest
    Diamond R Spyder Armrests and cup holders
    Wheel Aligment Squared Away
    Trailer Hitch Value Accessories
    Harbor Freight trailer black
    Stebel Nautilus Compact Mini Black
    139 decibel air horn
    Garmin GPS
    Feb 2012
    Spring City,Utah
    Be sure you remember to repack the HF trailer wheel bearings with decent bearing grease. They basically put cooking oil in at the factory and not very much of that.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Registered Users jon8622's Avatar
    May 2014
    Riverton Wyoming
    The HF trailer, but I removed some of the leaf springs and had the tires balanced. This pulled well empty. I used plywood for a deck, but many have used diamond plate aluminum.
    Sent from my NX16A11264 using Tapatalk
    Bryant, Arkansas
    BRP Freedom Trailer, Hooked it up and drove away happily. no extra work or parts needed.
    Cruzr Joe
    Feb 2011
    Hamburg, New York
    Default Trailer
    I bought the Harbor Freight Tag A Long Trailer and bought an after market hitch off eBay, I also used an after market tail light converter and connected it to OEM connectors from Tricled so it was all plug and play. The trailer pulled fine with the 8" tires, you may want to upgrade them to the 12". But you will need to upgrade the lights to LED's in order for them to flash correctly with the Spyder at least on the RT.
