Left Rear speaker does not sound
Esay to revise or involves a lot of work?
i think the second option.
Could be something else than wiring or simply broken speaker?
Radio unit?
Thx
What kind of spider do you have if it's an RT it has 4 speakers if the two front work and one of the rear does not work it's probably the speaker or a disconnected wire at the speaker this speaker is easy to get to. If the front ones work it's probably not the radio unit.
Mine is the RT 2011 Limited. Has 4 speakers but only the one next to the antenna doesn't sound.
I think probably it is a minor problem but do you know how to access to the speaker?
Is there some video about that?
Thank you.
Thank you!! At the end it was a wire connection problem and was not too much difficult dissasembly half spyder.
The truth is the first time you disassemble the Spyder it seems that you enter a new dimension.
When you do more modifications, maintenance and having your explanations and help things get much easier.
Thank you!
Ain't that the truth!!
