Federal tires
Is anyone running Federal tires on the rear, and what size are you running?
Monique,
2016 F3t pearl white
Ultimate driver back rest
12v power outlet for batt. tender
Doc Humphries' vibration damper
factory floorboards
added topcase
You burned through the rear already ???
Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
Tire
Just about, It's a Kehnda with 7600 miles on it.
The rally and vacation next month and it will need replacing for sure.
Monique,
factory floorboards
added topcase
SpyderLovers Ambassador
Rear Tire Options
I have a 2016 RT Limited, 7500 miles and the rear tire life is gone. Any Good tires out there.
I haven't seen a Federal rear in a 225/50 or 215/60. I am running the Kuhmo AST (225/-50-15, it has the H speed rating like the Kenda) and am happy with it. I would have preferred to find a V rated option for better traction but couldn't source one. When cold it spins up just as easy as the Kenda did, but once warm, traction is much better. Even when it is spinning, I get more forward motion than the Kenda gave when it was spinning....
Chuck
WELLLLLLL NOW THAT YOU MENTION IT
The Altimax also has " V " rated model , but it's actually not rated as high as the " T " rated one ..... jmho .... Mike
Chuck
GRIP /TRACTION
you must be referring to the treadwear rating? Cuz a V rated tire is built for higher speeds than a T rating ( 118 for a T and 150 for a V). I know the speed is a non issue with our machines but the compounds used in higher speed rated tires give better grip. ...
No I wasn't ........ I agree V is higher than T........ But - Higher speed rating has NOTHING to do with traction / grip ....... of course you may have a different understanding about Tires, but qualifications are based on Schooling & training for over 25 years. If your info is based on what tire Salesman, / women are telling you , my experience with them is 95% are clueless about the product they are selling ........... Mike
Chuck
tire
i have just bought a rear federal formoza 225/55r15. installing this week on my 2014 rts
225/55r15
I had not heard of a Federal Formoza in this size ..... I went to their Official website and couldn't find it there either ..... so what Federal Formoza do you have ???? ....... Thanks ....Mike
Formoza 225/55r15
DOH! The link said 225/55ZR15 and I didn't even notice when I copied and pasted!
Chuck
Many of us ride the Yokahama S-Drive 205/55/15 with excellent result. Traction has always been excellent. I have about 8,000 miles and may see another 8,000 before a change is needed. i’ve heard the size is very close to the originals.
That’s an easy mistake to make. Seems when you search on a specific tire size they will bring up just about any size tire.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
ALTIMAX RATING
Not Treadware - I was referring to it's overall Performance rating ....... Mike
ordered my vredstein, i should have them today
Is it hard to find our tire size is that why people run a different size? I've got a 13'RTS and I'm getting close to needing a new rear. Thanks
REAR TIRE
The main reason people are using the 215/60-15 in. size is because there are very few 225/50-15 tires to choose from. And this size will make your speedo almost perfect on the speed reading ( OEM size reads more than you really going ) if you get a General Altimax RT43 in 215/60-15 you will be very, very happy with the way it performs ....especially if you only put 17 or 18 psi in it .... It's a strong Auto tire and doesn't need higher air pressure to work correctly ........... Unless you have already done a rear tire swap your-self, I would make sure your Dealer will swap an Auto tire ........some re-fuse .....good luck .... Mike
Originally Posted by Ben Burped
I have been looking at rear tires all winter. In comparing the tire sizes on a web site the 225/60R/15 was listed as being over 7.75% bigger in diameter than the 225/50R/50. That site recommended not going over 5% larger in diameter over the tire size that came on the vehicle. What is your take on this suggestion?
If you're going to go with a xxx-60/R15 tire go with the 215-60/R15. There's no good reason to go larger diameter than that. The 215 fits good. As far as width there's no problem going one size narrower or wider than OEM. You really don't want to go 2 or more size over or under.
REAR TIRE
Well I wouldn't consider the 225/60r-15 size at all ..... The swing arm on every Spyder that I know of ....is very close to the tire using a 225/50-15 or a 215/60-15...... So if you go taller AND wider than that , I think you are asking for trouble ..... And I don't just think out-of-the-box ....I LIVE out there ...... But while I try things because I think they will work .... I keep in mind .....What is the benefit of this change or modification ..... The footprint you will attain using the 225/60-15 ( it will be an increase ) is so small ....the word " infitismal " comes to mind...... As I commented in another Thread about increasing tire sizes .... The Spyder is NOT a Hayabusa, which is a Mtc. that could more than likely actually benefit from a bit more traction if used at the Drag Track ....... I gave you one of the best tires our Spyders will benefit from ..... There is only one other person on this Forum ( that I know of ) who is as qualified as myself to give expert advice on using tires on our Spyders and that is Peter Aawen. Not boasting or BS-ing on this...... Mike
