User Tag List
Results 1 to 22 of 22
    Active Member Harvey's Avatar
    Jun 2013
    Rock Hill, SC
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Air Horn on Spyder RT Ltd.
    Has anybody mounted an air horn of the new 2013 RT Ltd? If so, what brand, model, where did you put it? Sometimes it is necessary to let people know you are there.
    Still a SpyderLover Bob Denman's Avatar
    Grahamsville, NY
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The Stebel Nautilus is the "Mac Daddy" of noise.
    GeoffCee wrote up a nicely detailed set of instructions on how to do it; the RIGHT way!
    I think that it's in the DIY section...
    Klaatu barada nikto
    Jul 2011
    Florida
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's always good to read and study someone else's efforts. However, since the battery on the 2013 RT is located up front there isn't room to install the horn up front as GeoffCee did. No room for an additional fuse box for additional farkles either. I, as yet have not figured out my horn install either.
    2014 Black RT SE
    Active Member shrubs's Avatar
    Sep 2012
    Dayton oHIo area
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the Stebel Nautilus on my '13 RT. I bought the horn and the wiring kit to make it basically plug-n-play. I mounted it where the original horn was.
    My pics are here: http://www.spyderlovers.com/forums/s...Honk-If-You-re
    The hardest part was removing all the tupperware to get access to the horn.
    USAF Retired (1986 - 2006)
    Ohio PGR Ride Captain
    Riding with Dignity, Honor and Respect
    Active Member WingmanRT's Avatar
    Charlotte, NC
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Stebel Nautilus
    Quote Originally Posted by shrubs View Post
    I bought a Stebel Nautilus and had a Can-Am dealer put it on, in place of the OEM one. My horn went from meep-meep to Beep-Beep. I am not satisfied. Maybe they installed incorrectly, or something, but it's almost an embarrassment. I had a guy pull in front of me on my way back from Lamont's last week or so. When I need to alert someone to my presence (i.e. my life is in peril) I want the horn to go WAAAAAAAAAAAAAAH!!!!!
    I want them to think an oceanliner is bearing down on them. I am looking into marine or trucker's horns mounted deep in the 'ram scoop' of the front Tupperware, pointed forward. Anyone go that route?
    Paul "Wingman" Metheney
    2011 Can-Am Spyder RT Limited
    Active Member DRTSB's Avatar
    Feb 2012
    Ottawa, Canada
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Horns
    I installed a set of Rivco Magnum Electric horns,
    http://www.rivcoproducts.com/product...cat=260&page=1,
    You also need the installation kit which is 40 bucks,
    http://www.rivcoproducts.com/product...cat=435&page=1
    There as loud as a large car which is a lot better then the Roadrunner horn it had, it installs under the right fog lamp, you don't have to drill anything you use pre exsisting holes and slip nuts, all the hardware for mounting on the Spyder is included in the kit, basicaly disconnect the stock horn, attach the supplied extention to the wire , hook up to the new horns relay, power from the battery through the supplied fused wire, install took me about 2 hours.
    Dave
    2011 Spyder RT Limited, drive daily (except when it's snowing)
    2012 Honda Fury VT1300
    1974 850 Norton Commando, drive daily, praying that it keeps running!
    2009 Goldwing GL1800 AD, traded in
    2009 Suzuki M109, (fast bike), traded in
    2011 Nissan Murano SL, S, ride to work
    Very Active Member Don in E Texas's Avatar
    Feb 2009
    Gilmer, TX
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Train Air Horn
    Once helped a gentleman install a set of railroad engine air horns on his Provost motor home. When all was finished, we gave it a test. Ground shook for 100 yards all around! I think if he sounded the horn out on the road, it would have people heading for the shoulder of the highway! Have to think of any state or local laws on the use of something like this. My Freightliner (RV toter) had a two horn system; air (pull cord) and an electric one (steering wheel button).
    Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
    Now Own: 2014 Black RT-S SE6
    May 2012
    Beaumont, TX
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Waaaaaaaaaaaahhhhhh!
    I put a Stebel Nautilus air horn on my 2012 RT and it makes a significant noise! I have definitely blown 18 wheelers away when they wanted to get up close and personal in the same space as me. Great investment! Safety farkle! You can get these and the wring harnesses for a reasonable rate at Amazon.com
    Charlotte, NC
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nautilus
    Quote Originally Posted by muonwhiz View Post
    I guess I am going to have to have mine checked. I bought one and had it installed and it is just a above a "meep"
    Very Active Member SpyderHands's Avatar
    May 2016
    Central Florida
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Updates?
    Let's resurrect a thread today!
    So, anyone have an OOGA horn on their Spyder F3?
    Any insights on LOUD SOUNDING horns on their Spyders?
    HAND'S UP:
    The only sure way of getting rid of bad habits is to create good ones.
    AND, by the way, this will not happen on auto pilot.
    It's time for a YOU-turn!!!
    Danbury Connecticut
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by WingmanRT View Post
    Definitely something wrong with the installation.
    There is a SIGNIFICANT increase in volume over the stock horn.
    My Gas Tank Is Full; My Bladder Is Empty
    Time To Motor On
    IBA #47122
    Grahamsville, NY
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Get yourself a REAL horn!!!
    Klaatu barada nikto
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SpyderHands View Post
    I got the attention of a dude in a high lift 4 x 4 pickup the other day when he tried to run over me. I have the Wolo trumpet horns on my '14 RTS. Here's how I installed a set on the 2013 RT I had. On the '14 I put the compressor behind the grill on the left side. http://www.spyderlovers.com/forums/s...hlight=trumpet
    Active Member SpyderConvert's Avatar
    Catonsville, MD
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I recently installed a Stebel on my '15 RTL, when I tested it after install it sounded more like a vibrator than a horn. I switched the connectors and found that I had reversed the polarity - it worked fine after that.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    Sep 2015
    Parkesburg,Pa
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Stebel is the way to go,make sure you use a relay so you don't overload the circuit.
    May 2018
    Atlanta
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Is this everything I "need"?
    Hi Everybody,
    If I bring this single kit (link below) to my local dealer, does it have everything needed to install a louder horn? I'm just trying to avoid buying insufficient parts for the task.
    https://www.amazon.com/dp/B077LY7HXK...v_ov_lig_dp_it
    Thanks!
    Richard
    2018 RT Limited
    Can-Am Driver Backrest
    Tricled Wide-Vu mirrors
    Spyderpops grips
    FOBO TPMS
    Lamonster Spyder Cuff
    Ram mount w/ X-Grip
    SpyderLovers Sponsor Roadster Renovations's Avatar
    United States
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Apr 2018
    WA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by RichardRubin View Post
    Hi Everybody,
    Thanks!
    Richard
    If it only comes with what's in the picture, you're not getting anything more than comes with the Stebel but are paying more than twice the cost of the Stebel. Basically you'll need the following to get it installed:
    • Air horn
    • Relay
    • Wire, connectors, maybe fuse, to get high current positive power to relay
    • Wire/connectors for relay ground
    • Wire/connectors to connect stock horn wire to relay
    • Necessary material for mounting as desired
    I'd think that most dealers would have all this on hand, but I'm sure it varies. Maybe call and discuss with your dealer and see what they need you to supply?
    Catonsville, MD
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Installation
    When I switched horns to the Stebel, I used the original wiring. The advice that I was given said that unless you are going to "lay on the horn" for more than 10 - 15 seconds, you would not need the relay. The horn worked beautifully on a 700 mile charity ride this past weekend. The only problem that I encountered with the installation was trying to drill out the smaller hole on the brackets that the original horn was mounted to - without a drill press, they twisted and bent when I tried to make the hole larger. I remembered that I had some 1/4" aluminum bar stock laying around, so I cut it to the length of those originals and drilled the holes in the original location. Worked like a champ! That bracket improvisation took the most time, it would have otherwise been a 20 minute install. Save some money and do it yourself after watching the above video, the only tools that you'll need are 10 and 13mm wrenches.
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Horn
    Quote Originally Posted by SpyderConvert View Post
    I too installed my horn without the relay. I only use the horn when necessary and for short bursts. Have had it in for a year now with no problems.
    Dec 2015
    Oakley Utah & Hurricane, Utah
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's what I have. Not as loud as a trucker's horn but a definite improvement over the OEM.
    2014 RTL Magnesium & 2014 RTL Cognac
    Northern Utah in summer; Southern Utah in winter
    Dec 2015
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Roadster Renovations View Post
    WHICH air horn is this?
