Results 1 to 8 of 8
Thread: Belt Alignment
    Jul 2016
    Grove City, Ohio
    Default Belt Alignment
    I changed my tire a couple of weeks ago and finally got a good ride in. However, when I ride it appears the belt is on the inside edge of the tire sprocket hub. I did not move my tensioners and I am not sure if it is rubbing to much or not. Before the tire change, the belt looked like it was in the same position however I think I smell a faint rubber burn. Not sure if it is the new tire or the actual belt. I can pull the belt to the outer edge of both sprockets (drive sprocket and tire sprocket) and it will move right back to the inside of the tire hub and the inside of the drive sprocket. Should I leave it as it is or move the tensioner to get it a millimeter away from the inside tire sprocket?
    Quote Originally Posted by Spyder 10 View Post
    The belt needs to be away from the flange. Somewhere near the middle of the sprocket is good even the though the spec is 1 to 3 mm. I can't agree with the argument that is made here quite often that not messing with the tensioner blocks will get the belt back to where it was. Most of the time, probably, but not all the time. I ended up having to adjust the tracking after I changed my rear tire. In my case the simple act of tightening the axle nut moved the axle enough to upset the alignment. Search for my name and alignment to see my post about it. If you can't find it let me know and I'll look for it.
    Sep 2016
    Alma,Arkansas
    Double check the belt tension, very important. In the previous posting it was noted that alignment should always be checked, just a minor movement in the axle position can cause major misalignment.
    Good Luck
    Jul 2010
    Las Vegas, NV
    Default Test
    Jack up rear tire. Spin tire by hand forward 10 revolutions. Check belt. Spin backwards 10 revolutions. If belt migrates the axle is not square in the swing arm. Loosen axle nut, tighten the left swing arm axle adjuster one flat. Snug nut, spin tire 10 X in each direction. Normally one or two flats of the Allen gets it done. If you need help, call me. Joe
    Joe Meyer
    United States
    I problem I first had when doing tire changes, etc. was that the right adjuster would loosen slightly when I tightened the axle bolt/nut down. I learned to use a plastic beaded hammer to tap the axle nut gently so I had no play in either adjuster. That has always worked for me. I bet if you check, one of the adjustment lugs (where the allen wrench goes) will have a little play.
    At a rally in North Carolina last year, we had to adjust a ryders' belt 17 times before we pulled it off the shoulder of the rear sprocket. It was 2 1/2 turns in on the right side. Worse I had ever seen. He also complained of a rubber burning smell and you could see the edge of the belt was chuffed.
    Good luck!
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Quote Originally Posted by Doc Humphreys View Post
    That is exactly what I do, due to play in the tensioners.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Registered Users lou49's Avatar
    lake mary fl.
    I got the same problem and even though on my 08 gs i correct it my self, this time ill take it to the dealer! Funny! I check out a slingshot n the pulley has flanges on both sides!
    United States
    Quote Originally Posted by lou49 View Post
    What kind of length was the belt on the SS? Longer than ours?
